clutch help on LS teg
Old Oct 1, 2008 | 04:40 PM
LSfreak's Avatar
In Yo Face
Default clutch help on LS teg
was wondering if a hydraulic clutch is adjustable cuz mine grabs when the clutc is almost out. yes its a new stage 2 clutch and fluid has been flushed out.
TR "Old Skool EF" Member #155
"Type R lip and tongue"
http://www.myspace.com/highstack101
Old Oct 1, 2008 | 06:59 PM
Thatguysstuff's Avatar
Hey its that guy!!
did you bleed it???
maybe bad slave cylinder?
Old Oct 2, 2008 | 01:21 PM
LSfreak's Avatar
In Yo Face
its been bled and flushed out and new fluid put in. slave cylinder is new
Old Oct 2, 2008 | 02:06 PM
freakasis's Avatar
when you say "new stage 2 clutch" did you get a clutch kit with a throw out bearing/pressure plate/disk? because not all throw out bearings will work with all disks. i used a new OEM bearing and act 6 puck and i couldnt shift at all, the bearing was rubbing on the middle of the disk. when i got an autozone bearing my clutch was right at the top like yours is. if you didnt get a kit you might have a similar issue.
Old Oct 2, 2008 | 02:31 PM
Us3rname's Avatar
Shit on debras desk
The only way you can adjust your clutch pedal is from the bolt under the dash the the clutch pedal part of the assembly. If you do this make sure to adjust the safety switch on the clutch as well or your car won't start. if that switch is not working then you can skip that part.
1 2 3 4 trumpet elf
Old Nov 4, 2008 | 02:43 PM
LSfreak's Avatar
In Yo Face
im just going to get a new master cylinder for the clutch
Old Nov 4, 2008 | 02:44 PM
LSfreak's Avatar
In Yo Face
it was a complete kit with both bearings
