No Spark+No Fuel=No Start
Old Sep 11, 2008 | 09:07 AM
TechChild's Avatar
Got Rice?
Default No Spark+No Fuel=No Start
Hey I've got a problem my car wont run it hasent run since saturday.
I was driving along on my way out to causeway just put in my new turbo on tuesday or so but the mechanics that redid my oil return line for me screwed it up pretty bad and I had to redo it and this was pretty much a test drive (I had driven it for roughly 10 minutes before hand)
I was driving along all of a sudden check engine light car turns off it wasent over heating it was running perfect but had a strange burning smell under the hood, I have been told it was the distro so we replaced the rotor and another part of it still havent replaced the icm, changed the spark plug wires. Still wouldent fire still has no spark also the fuel pump wasent priming replaced the fuel pump with a Walbor 255 still wasent priming and the car still isent giving spark. Replaced the main relay still no spark or fuel. Any one know what this could be it's a d16z6 with a turbo set up 450 injectors walbor 255 fuel pump, t25 turbo, and has a john vega basemapped ecu (I was so excited that I was actually going to be able to get tuned with everything correct and then this happend) Also we tried to pull the code it wont pull a code at all. If any one has advice please let me know.
Old Sep 11, 2008 | 11:01 AM
TechChild's Avatar
Got Rice?
Any thing to do to trouble shoot this?
Old Sep 11, 2008 | 02:23 PM
BABILLARACING's Avatar
you got pulse? if not cause you said you put a new main relay check the ecu and/or check the 15 amp fuse in the engine compartment fuse box if is it a 92-95 I will be the first one on the top left if you are standing in fron of the car hope this help.....................Omar
also you said 450 are they from a eclipse? if they are you have the resistor box on them ?
Old Sep 11, 2008 | 04:13 PM
TechChild's Avatar
Got Rice?
Yah I have the resistor box, lol we got it to run turns out it was a $16 dollar distro cap.
