shift linkage??
Old Sep 6, 2008 | 11:44 PM
wb_map3's Avatar
Default shift linkage??
my boy has a dc with the b18 in it so im pretty sure it still has his b series shift linkage...he just got it so he doesnt know...but you know how if the car is in nuetral you can move it from left to rite and rite to left...basically you can move it all over from side to side well his problem is you can do that even in gears..you put it in 1st and you cant tell if its 1st or nuetral and the same with every other gear...makes it really hard to shift lol alot of missed shifts going on and we need to fix it asap...
im grown but yea bitch i got batman bedsheets
Old Sep 7, 2008 | 02:41 AM
mtber's Avatar
Sounds like he isn't using an oem honda shift pin (pin that connects the shift linkage to the transmission). Don't use a bolt/nut. Use a factory shift pin.
Old Sep 7, 2008 | 02:57 AM
wb_map3's Avatar
thnx but i already checked that it is oem and the front bushings are good...the back bushing was fucked but i replaced it for him and its still doing it...
