1995 Accord question HELP!
Old Aug 19, 2008 | 06:10 AM
biggnick's Avatar
PS3: BiggNickTR
Default 1995 Accord question HELP!
Have a 1995 Honda Accord EX sedan. This thing runs really well considering the miles, I haven't owned it that long.
A problem arose starting last week with the overdrive. It usually occures when the car is warmed up. I'll try to explain it the best I can.
The car shift smoothly and without issue. Once I am at cruising speed (fourth gear), the car starts to "studder" when cruising/accelerating slowly between 1500 and 2000 RPM. It's almost as if the car isn't "breathing" right. If I floor it, it downshift and accelerates with no issue. It only happens between those two RPM levels and only in fourth gear...and the kicker is it doesn't happen every time, just when it wants to! Occasionally it will also happen in reverse, but only when applying gas.
I tested the tranny fluid in nuetral and while the car was in gear and everything seems normal. The fluid is pink-ish, there is NO burning smell, and no metal shards. Again, the car shifts perfectly otherwise and runs great. There is no slippage or hard shifting. My mechanic buddy stopped by really quick, tested it out, and advised me that it most likely wasn't a tranny problem but a sensor issue, like the car (at those RPM's) wanted to switch between the overdrive gear and the passing gear constantly but doesn't.
I have also read online that a bad EGR valve could cause this. Considering how great the car runs otherwise, I am inclined to believe the tranny is doing fine. Anyone have any ideas/experience with this? Sensor or EGR? Something else?
Old Aug 19, 2008 | 05:17 PM
biggnick's Avatar
PS3: BiggNickTR
Anyone?!?
Old Aug 20, 2008 | 02:12 PM
biggnick's Avatar
PS3: BiggNickTR
where the heck is all the help at ?
Old Aug 22, 2008 | 03:21 PM
biggnick's Avatar
PS3: BiggNickTR
ttt...
Still looking for help
Old Aug 22, 2008 | 03:24 PM
biggnick's Avatar
PS3: BiggNickTR
ttt...
Old Aug 22, 2008 | 05:00 PM
jcarp613's Avatar
Either Fluid Viscosity, or There are 2 shift relays on the tranny. They can go bad. I had a 94 that did the exact same thing. I would change the fluid 1st. If that doesn't work, have the relays on the tranny checked.... good Luck!.....
Old Aug 23, 2008 | 09:48 AM
biggnick's Avatar
PS3: BiggNickTR
thanks!
Is the relay fix expensive? I know manuals, not autos
Besides those two times, the transmission runs strong and smooth. Fluid looks/smells clean, maybe too thick or not thick enough?
Old Aug 23, 2008 | 10:12 AM
jcarp613's Avatar
The fluid viscosity could be thin from normal driving. It happens from it heating up and cooling down a several hundred times. If it has only done it 2 times, then I wouldn't worry too much. as far as the shift relays, they are $130 each and Dealer only parts. Make sure you test them 1st. Dealers won't let you return electronic parts. Good Luck....
1990 Acura integra Part out! DA. Doors, Catback, Windshield, Wing, Etc...
https://www.tamparacing.com/forums/h...ml#post8243584
D15B2, 5spd Cable Tranny, Dizzy, A/C Parts, Starter, Axles, Tons of D Parts
https://www.tamparacing.com/forums/h...s-d-parts.html
