b20b help
Old Jul 26, 2008 | 04:30 PM
blueyez829's Avatar
Default b20b help
need help on b20 it only rev to 6000 rpms on a stock LS ECU.i change the ECU to with another LS ECU and still the samething OBD1 wiring what can it be.....
Old Jul 29, 2008 | 04:43 AM
quick91integra's Avatar
- 7$t BOYZ -
B20B
  • 1996-1998 specs
  • NON-VTEC
  • Found in: JDM Honda CR-V, Honda Orthia
  • Displacement: 1973cc
  • Power: 126 hp (94 kW)) @ 5400 rpm
  • Torque: 131 ft·lbf (178 N·m) @ 4300 rpm
  • Rod length: 137mm
  • Compression: 8.8:1
  • Bore: 84 mm (3.3 in)
  • Stroke: 89 mm (3.5 in)
  • Redline: 6300 rpm red line
  • 1999 - 2000 specs
  • NON-VTEC
  • Power: 146 hp (109 kW)) @ 5400 rpm
  • Torque: 133 ft·lbf (180 N·m) @ 4300 rpm
  • Rod length: 137mm
  • Compression: 9.6:1
Looks about right.
$$$$$$$POLAND$$$$$$$
TR "OLD SKOOL DA" MEMBER #006
...now me and the mad scientist is going to have to rip apart the block.. and replace the piston rings you fried...
No sittin at the table if you bringin nothin to it!
Some Acura parts for sale.
Old Apr 13, 2009 | 09:32 PM
Ls_[eg]hatch's Avatar
mowchowbrowncow
ecu throwing any codes?
Old Apr 14, 2009 | 05:23 AM
sprjit22's Avatar
Rick James bitch
Put a timing light on it and see how many rpm's it is spinning bc the tach could be off a little.
The motor will rev to what ever the ecu allows it to rev to.
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old Apr 14, 2009 | 11:06 AM
custom240sx's Avatar
DC Crew Member #1
Yes exactly as mentioned above...does not matter what the rated rev limit is...the motor will rev to whatever the ecu allows it to rev. LS ecu's go to 6900rpm...that tach is probably off. Hook up an aftermarket tach and see or a good timing light will give you your rpms.
