car wont idle
Old Jul 7, 2008 | 09:50 PM
slizzle's Avatar
has a new plan in action
Question car wont idle
its a 92 accord with the f22a1 and the car should idle ROUND 600-700 RPMSbut its climing up to 1500 rpms and drops to 1000 and repeats unless i put on the A/C whats goin on
you gotta get it from the muscle cuz dont nobody owe you nothin
Old Jul 8, 2008 | 11:21 AM
slizzle's Avatar
sombody say something
Old Jul 8, 2008 | 11:27 AM
marktopia's Avatar
TR Balla Donor Supreme
might be ur map sensor or ur idle control senser
Old Jul 8, 2008 | 12:06 PM
slizzle's Avatar
thanks
Old Jul 10, 2008 | 12:39 AM
slizzle's Avatar
anybody esle got input?
Old Jul 10, 2008 | 05:36 AM
wolfenr1984's Avatar
Great White Hope
does this car have a iacv (idle air control valve)? if so, it could be dirty and in need of a cleaning or it may need to be replaced. do you have any vacuum leaks? this could include both gaskets and hoses, which are cheap to replace, whereas the iacv is not, if you have one.
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
Old Jul 10, 2008 | 09:30 AM
Thatguysstuff's Avatar
Hey its that guy!!
ive seen it from the Idle air control valve (IACV) or the Map (mass air) or the valve under the throttle body... Cant remeber the sensors name...
i had to do them on a few of my accords... allot of civics have the same problems..
Old Jul 10, 2008 | 09:37 AM
Juiced Dc2's Avatar
TR Events Admin
first thing to do is start the car and block off the throttle body with your hand and if it continues to run start lookin for a vaccuum leak if not I got 50 bucks on fast idle valve its the valve in the front of the I.M. with 2 vacuum lines coming off of it, or it could be the electronic air control valve on the front left of the I.M.
We are what we repeatedly do. Excellence, therefore,
is not an act but a habit.
-Aristotle
Old Jul 10, 2008 | 11:40 AM
slizzle's Avatar
oh and when i get the car above 30 the car will idle at 1500 and stay there untill i slow down under 25 it will start to do what i stated earlier
Old Jul 14, 2008 | 03:43 AM
sired00fury's Avatar
K-Series HONDA
Check the tps sensor( throttle position sensor), timing could be off, or the idle air control valve. Clean the screen out. Id also consider taking off the intake manifold and checking for cracks. If thats not the problem maybe when you put it back on it was the gasket all along. If thats not it. VACUUM LEAK. Replace the little hoses that connect to the mani.
