civic question
Old Jun 26, 2008 | 04:15 PM
dizzythunder's Avatar
Default civic question
i put a new temp. sensor in, a new fan relay, and checked the fuse under the dash. then hard wired the fan and it worked.
why wont the fan turn on like it's sup. to?
Old Jun 26, 2008 | 04:28 PM
DemonCivic's Avatar
bad fan switch
Old Jun 27, 2008 | 04:11 AM
where is the fan switch located?
Old Jun 27, 2008 | 12:36 PM
DemonCivic's Avatar
sounds like the temp sensor you replaced was the one for the computer. the other single wirre temp sensor is for the fan. if you ground the wire with the key on, your fan should come on.
Old Jun 27, 2008 | 03:51 PM
i replaced the one under the dizzy with the single wire, where is the one for the computer
