Professional products throttle body problem…..
Old Jun 16, 2008 | 09:34 AM
CBURKE's Avatar
Has to many projects
Default Professional products throttle body problem…..
I got this from a guy and it is made for a GSR, I have a B16A. As you know the throttle cable braket is kind upside down on the GSR. I need the bracket to be flipped. Easy right? Well the B16 TB I have, the hole is to small. It's also to small to get anything in there to make it a little bigger.
I call the company and they are no help. I was told I would have to use the Type-R arm.........Good luck on that!!!
Does anyone know of anything I can do? Or will the LS work?
Thanks for any help
Cburke.industries.
Custom suspension bars, metal fabrication.
Old Jun 16, 2008 | 01:26 PM
CBURKE's Avatar
Ttt
Cburke.industries.
Old Jun 16, 2008 | 01:31 PM
mtber's Avatar
Install a gsr throttle cable bracket & a throttle cable or change the spring assembly to a b16/type-r.
Old Jun 16, 2008 | 01:49 PM
CBURKE's Avatar
I would have to replace the whloe shaft to do that. I have a b16 TB and I took the spring and the cable arm off, the hole is to small. I really don't want to go with the GSR cable. The type-R must have a bigger TB shaft....not sure.
I am just going to have to sell this damn thing!!!
Cburke.industries.
Old Jun 16, 2008 | 01:50 PM
CBURKE's Avatar
I'll have better pics up tonight.
Cburke.industries.
Old Jun 16, 2008 | 04:18 PM
T4eg's Avatar
sell it and buy the right one, they are only like $100
9.81@ 155 - turbo street B18 retired SOLD
9.91@ 144 - turbo street 10.94@ 137 225 50 bfg stock block
9.10@169 - turbo street 24.5 mt
9.38@ 144 all motor
8.76@ 176 outlaw street
www.clutchmasters.com
www.tempestracing.net
Old Jun 16, 2008 | 04:59 PM
mtber's Avatar
On factory tb's you can swap out the spring & gold plate....
