Valve seals or piston rings? (how to tell the difference)
Old Jun 2, 2008 | 07:47 AM
Jason2801's Avatar
It is what it is
Default Valve seals or piston rings? (how to tell the difference)
Hey everyone well my question is this how can you tell if your car has bad piston rings or if the valve seals are bad??
-My car drives normal and fine but when I push the car passing 6 RPM's it smokes a lot (white smoke) and does it for like a 30 seconds but then stops smoking. Once again it only smokes when I push the car at high RPM's, IDK if its the valve seals or piston rings. Please let me know what you think or what the difference would be on how to tell which one is bad thanks.
Old Jun 2, 2008 | 08:11 AM
zeroboost1's Avatar
Well it sounds more like you need rings.
Dose it smoke right when you start it after it has sat for a while,? if not then probly rings but its hard to give you a solid answer over the net.
So gl and if you need help my nunber is in my sig.
Cory
CAM-Mobile-Performance&Repair
For All Your Performance And Repair Need's
Done At Your Spot Or Mine.
I do every thing from ECU chipping, swaps and custom wireing to audio and alarms, even suspention and alignment's.
We will be tuneing very soon E-MAIL me at CAMPERFORMANCE@yahoo.com
For any questions or to set up an appt.
Cory .M
Old Jun 2, 2008 | 08:30 AM
Jason2801's Avatar
It is what it is
^ well when I start the car and drive it normal it doesnt smoke at all, but if i push the car I notice a lot of white smoke coming out from the exhaust by looking at my rear view mirror when ever I start passing 6 RPMS it starts smoking and when i stop some smoke is still coming out not as bad as when I'm pushing it though but the smoke stops like 30 seconds after i stop pushing the car.
Old Jun 2, 2008 | 09:35 AM
Thatguysstuff's Avatar
Hey its that guy!!
compression check it yet?
Old Jun 3, 2008 | 09:18 AM
Jason2801's Avatar
It is what it is
not yet, I'm going to see if I do that this weekend.
Old Jun 3, 2008 | 09:47 AM
-faded-'s Avatar
infraction king
sounds like what motor did many years back, it was the rings
98 E36 ///M3 Sedan
07 Civic Si Sedan
Old Jun 5, 2008 | 07:59 AM
rangcrx's Avatar
engine building &best
^ yup you will also need to have your motor honed when you put the New RIngs in it does it at high rpms just do to the pressure and small amonts of oil dripping thru the tiny grooves in the walls over time"nothing bad"
i love AUTOZONE
Old Jun 5, 2008 | 04:41 PM
MightyMaxGS-T's Avatar
yup do rings and valve seals, might as well, it'll be all apart...
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
