intercooler sprayer kit?
Old May 31, 2008 | 09:48 AM
JDM son!'s Avatar
Professional Hustler.
Default intercooler sprayer kit?
i have done some reserch on them and found out the can help out alot if used in the right conditions. i dont have the money to buy one but i would like to build my own dose anybody know where i can find a write up about them?
MONEY IS THE MOTIVE.
Old May 31, 2008 | 10:07 AM
dippincrx's Avatar
save the s.o.h.c
i wanna say i read article in import tuner, maybe honda tuner like 5 years ago about a sohc crx w/ a homemade intercooler water sprayer. used hose w/ a nitrous jet and the stock windshield water bottle and pump to spray the intercooler.
or you could always just get a full bottle and have a buddie run to the car each time and spray it like that. hahaha
Old May 31, 2008 | 10:11 AM
DemonCivic's Avatar
~Just get a co2 regulator to drop the psi down to like 150 coming out of the bottle.. u can get this off ebay by searching for welding supplies or a kegerator they are like $15 for one that handles 4000psi and can drop it to like 1psi
~An electronic solenoid for an airhorn and connect it to a switch in the car $3 if that.. (when u hit second gear hit the switch and just spray the intercooler with freezing cold co2 the rest of the way down the track. when you finish turn it off)
~some thin copper tube and drill small holes in it for the sprayer itself..
~get a co2 tank filled.. connect it all together with some cheap vacuum line and its done.
Old May 31, 2008 | 11:13 AM
JDM son!'s Avatar
sounds easy lol, what size vaccum line do you suggest?
Old Jun 1, 2008 | 05:51 PM
zeroboost1's Avatar
But wont co2 take away power if it gets sucked up the intake track?
Just a thought and gl.
CAM-Mobile-Performance&Repair
For All Your Performance And Repair Need's
Done At Your Spot Or Mine.
I do every thing from ECU chipping, swaps and custom wireing to audio and alarms, even suspention and alignment's.
We will be tuneing very soon E-MAIL me at CAMPERFORMANCE@yahoo.com
For any questions or to set up an appt.
Cory .M
