EG question.
Old May 26, 2008 | 12:58 PM
khmai memoriez's Avatar
Yank Krew #1
Default EG question.
i need help ASAP. My Hatchback won't turn on. everythun else is working like the alternator and the starter. but da problem wen i crank the ignition it jus chokes and dies. have anyone had da problem? Would yall think its the main relay? need help aSap!
YANK
KREW MEMBER #1
"~DC CREW MEMBER # O~"
For Trance/Techno Lovers! Here's a Thread For YOU
https://www.tamparacing.com/forums/p...no-thread.html
Old May 26, 2008 | 01:32 PM
DemonCivic's Avatar
start by checking for spark and fuel pressure, then you can isolate the system causing you the problem
Old May 26, 2008 | 02:02 PM
Yank Krew #1
thanks. I checkd the spark. its works. but its the fuel pressure. my dad has a fuel scale thing and it tells me wen i got pressure. sometimes it dont wanna start. like jus now i jus went back to my work place and went to do the fuel meter and it got to 35 and i startd the car and it run but i had to hurry up and bring it home. wen i was come n home it started to back fire. luck i got it home. rite wen i got on the parking lot it jus died out slowly. wa would trigger that tho would u happen to no?
YANK
KREW MEMBER #1
Old May 26, 2008 | 03:34 PM
DemonCivic's Avatar
when it wont start what is the fuel pressure at?
can you hear the pump running?
could be a few things, need a little more info
Old May 27, 2008 | 06:10 PM
hatchattack's Avatar
More info, sounds like you may have a fuel pump on its way out.
