car running hot???
Old May 13, 2008 | 07:44 AM
JoKiE crx4294's Avatar
popeye built!
Default car running hot???
new radiator, new thermostat new head gasket and arp headstuds. car runs very cool when it is just sitting and idling, but as soon as you start moving the temp starts to go up and depending on how fast i am going the temp gets even higher. seems like the water pump is not working properly? any other idea's?
Can't spell strength without tren
AAS...It's whats for dinner
Old May 13, 2008 | 08:08 AM
SiR-Drew's Avatar
change the water pump.
Old May 13, 2008 | 09:52 AM
zeroboost1's Avatar
Is your fan comming on? If it is I would also say change the water pump gl.
CAM-Mobile-Performance&Repair
For All Your Performance And Repair Need's
Done At Your Spot Or Mine.
I do every thing from ECU chipping, swaps and custom wireing to audio and alarms, even suspention and alignment's.
We will be tuneing very soon E-MAIL me at CAMPERFORMANCE@yahoo.com
For any questions or to set up an appt.
Cory .M
Old May 13, 2008 | 10:45 AM
popeye built!
the water pump is brand new. maybe 2 months old. is there something i can get that i can run through the cooling system to clean the water pump? it probably has rust deposits because i run water instead of 50/50
Old May 13, 2008 | 11:12 AM
popeye built!
how can you tell if the water pump is curculating?
Old May 13, 2008 | 12:32 PM
TheRedDragon's Avatar
i had a brand new non oem pump go bad on me and it was only a week old car would run hot and then randomly the gear popped of while driving! luckily the car shut off and the motor after new oem pump made 570. also make sure fans are coming on etc.
ALPHA TUNED
Tuning, Builds, Assembly, Turbo Installs, Repairs and More
inductionperformance.com
Old May 13, 2008 | 12:49 PM
popeye built!
it is an oem acura pump.
