1.5 runs good half the time
Old Apr 26, 2008 | 10:05 AM
MTXaudioSYSTM's Avatar
Slow V6 Firebird
Unhappy 1.5 runs good half the time
ok well half the time my crx runs like crap and the other time runs perfect
its a d15b6
misses a bit unless your accelerating and idles rough when it doesnt wana run good
back fires once in a while when sitting at a light
did a tune up on it, ran sea foam thru it, adjusted the vavles
i was gona swap it out but money got really tight
any idea? thanks
Old Apr 27, 2008 | 04:15 AM
redcoats1976's Avatar
had to replace the distributor on mine with 170k miles on it,sounds like yours is doing the same things mine was.when you sit at stoplights does it miss occaisionally?
Old Apr 27, 2008 | 06:07 AM
Slow V6 Firebird
yeah its the original dizzy
ima scrape up a few bucks and go get one
because since its the orginal and all waitin for it to quit on me
thanks for the help repped
Old Apr 27, 2008 | 06:44 AM
DemonCivic's Avatar
any codes?
Old Apr 27, 2008 | 07:49 AM
Thatguysstuff's Avatar
Hey its that guy!!
what dizzzy you need??? a dual port one??
i have a good one laying in my backyard...
20.00
Old Apr 27, 2008 | 03:50 PM
Slow V6 Firebird
nah havent hooked it up to the scanner just fried it on a car with a computer issue so i sent it out to be replaced
but no its not dual port otherwise i would take u up on that offer
Old Apr 28, 2008 | 08:47 AM
Hey its that guy!!
I also have a 91 crx si Dizzy..
witch is MPfi..
id let it go for the same 20.00
or you could test it on your car to see if you need it at all.
Old Apr 28, 2008 | 09:04 AM
CBURKE's Avatar
Has to many projects
Sound like that may be it.........and you don't have to hook the car up to anything to see if it is running any codes. The ECU flashes.
I would say the timming is off but you say this does not happen all the time. Try the dizzy can't hurt for $20.00.
Cburke.industries.
Custom suspension bars, metal fabrication.
Old Apr 28, 2008 | 09:16 AM
Slow V6 Firebird
yeah i pmed him
thanks for the help guys
