compression ?
Highest safe or the highest usable without de-tuning ?
You could de-tune a 12:5:1 motor on 93 oct and not have any detonation issues, however the motor will be screaming for better fuel then 93 oct.
If your looking for a good all around compression ratio for a 93 oct bseries setup I would recommend 11.5:1-12.0:1 with an 81-82mm bore
i did myne at 11.0:1. u could get away with higher. if you want to be safe....11:5:1 at max on pump gas will keep you from de tuning.
Stock injectors are only good till around 195-200 whp along with the stock fuel pump.
I have seen stock fuel pumps give up at 195 whp on older eg hatches.
I would recommend a set of 310cc injectors along with a walbro in-tank fuel pump for the 1.8L ls/vtec you are looking to build.
That is not possible on one tune, you would need two separate tunes using dual mapping. One on 93 and one on the higher octane fuel. You would want to use the same exact fuel every time on the higher octane fuel as different fuels have different properties.
How can I seperate using dual mapping besides a piggyback? Is there another way?
I was hoping for 205-215 whp ...I have a set of 370Cc injectors is that over kill?
And thanks for all your help
Just rode in my buddy's hatch you tuned last week Lil sohc suprised me lol
370cc injectors will work just great for the setup.
