radio doesnt work, clock resets
Old Feb 21, 2008 | 06:08 PM
freakasis's Avatar
Default radio doesnt work, clock resets
93 civic.
the ground wire for the radio doesnt connect to the body and every few days the clock just flashes brighter and resets to 1:00 im thinking these are both cause by the same problem...anyone know where in the wire would be a good place to start looking? or should i just run a wire from the radio ground to the chassis and see if it fixes the prob? by the way, the fuses are fine.
thanx
Old Feb 22, 2008 | 02:07 AM
lzylst's Avatar
radio and clock are related to the 7.5 amp fuse in the under hood box ....replace it even if it looks ok.
Vance @ 863-604-2139 for any questions
Old Feb 22, 2008 | 09:05 AM
94jdmeg6civic's Avatar
if not that then look at the wiring for the radio if aftermarket or if you have taken it out
Old Feb 22, 2008 | 05:31 PM
freakasis's Avatar
will do
stock harness...but no radio will work in there, iv tried a known good stock radio.
thanx for the input. does anyone where where these two items actually ground at?
Old Feb 23, 2008 | 08:14 AM
freakasis's Avatar
i only saw one 7.5 amp fuse...and a diagram online (dont have one) said it was the "back up" fuse....is that the one you are talking about?
Old Feb 23, 2008 | 10:19 AM
Derka's Avatar
TR Balla Donor Supreme
yep thats the fuse, should fix your problem
1998 crv daily beater
Old Feb 23, 2008 | 05:48 PM
freakasis's Avatar
fuse changed...we'll see if it works.
Old Feb 24, 2008 | 06:23 AM
DemonCivic's Avatar
should work, ^good advice
Old Feb 24, 2008 | 06:31 AM
freakasis's Avatar
i found the ground for the radio...its on the underside of the steering column behind the dash plastic. and it wasnt hooked up...it fixed that problem.
only time will tell if the clock is fixed...thanx for the help guys.
Old Feb 28, 2008 | 07:48 PM
Lee K's Avatar
DCLee
heh, heh . . .
