eg b series swap mounts as stock replacements?
Old Feb 15, 2008 | 08:53 AM
dippincrx's Avatar
save the s.o.h.c
Default eg b series swap mounts as stock replacements?
i need new inserts for my eg d16y8. looking on hasport the stock replacements i see the tranny and rear are the same as the 94-00 teg i know the drivers upper is diff for sure as i have the dx mount brkt
Hasport Performance Online Store
now here is my question if i get eg bseries swap mounts and change my driver brakted to the ex type can i use these mounts as replacements instead of spending over 200 for stock replacements.
rep for any help
Old Feb 15, 2008 | 05:17 PM
dippincrx's Avatar
save the s.o.h.c
wow i would have figured someone would have tghought of this at some point
Old Feb 17, 2008 | 05:00 AM
dippincrx's Avatar
save the s.o.h.c
well i searched and searched and figured they can be used. you just gotta make sure you get the right one. the trans brkt are the same but the engine depends on the current mount. you can either have the big aluminum mount w/ a three bolt setup or the steele mount w/ a two bolt setup.
