wanna make my motor v-tec! help!
Old Jan 26, 2008 | 05:12 PM
baseballpro5's Avatar
Default wanna make my motor v-tec! help!
i got a 92 integra with a b18a1. i was wondering what would be the best head for that block. and if anyone new any sites or links so i can read up on makeing it vtech to do it myself
Old Jan 26, 2008 | 05:47 PM
CEMAYHALL's Avatar
www.CEMayhall.com
vtech swaps.
Still worded it wrong .
Old Jan 26, 2008 | 06:05 PM
EGKID's Avatar
Here I'll help you out this time
This the best write I've seen
Honda-Tech.com: All Motor: How to build a "reliable" lsvtec/b20vtec
Ricky
Old Jan 26, 2008 | 07:59 PM
StrictlyBusiness's Avatar
Mr. Stealyogirl
b16 ftw
www.jdmmindz.com
Lurkin' in a hood near YOU!
Old Jan 27, 2008 | 05:42 AM
MightyMaxGS-T's Avatar
i personally prefer a gsr head, for the fact that the shape of the combustion chambers seem to be a little more well suited for all motor performance. plus it has a lower cylinder head cc so you will have more compression no matter what piston you decide to use. make sure you follow that guide though. arp rod bolts, b16 or itr pistons, a block girdle, and head STUDS are a definate must in order to create a reliable setup. you may also want to consider cryo-treating and shot peening your rods. btw, the best way to start an ls/vtec swap is to realize that vtec does not end in h! you will find a lot more in your searches that way. i actually have a set of b16 pistons in perfect condition if you are interested.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
