Help!!!
Old Jan 4, 2008 | 06:26 AM
Jmoney45's Avatar
Default Help!!!
does any one no if a camber kit from a DC2 1994-2001 will fit on a DA 1990-1993???? and if so what else would fit on it from another honda like a civic or accord ect.... or what brake rotors will fit on a DA from any kind of honda???
Old Jan 5, 2008 | 05:53 AM
terry.ho's Avatar
I love to choke people.
According to Ingall's they are the same. As far as the other stuff do some research. Go to websites and look at catalogs. If the part numbers match then they are interchangeable. There are some parts you can swap as upgrades. There is more than enough information on the web. Google
Originally Posted by fresh&clean
This is the worst place to get any advice at all.
http://www.myspace.com/terry_ho
Old Jan 5, 2008 | 06:55 AM
Outkasted24's Avatar
** I ♥ Old Skool **
Currently There is only one Upper Control arm/Camber Kit for the DA, And that is by Skunk2 ( just released in '08 ), & Yes... You can use an Ingalls kit on the DA, but there are some modifications you'll need to do to your inner fender and upper control arm if your lower then 2.5 inches and need to adjust to a 0 degree.
My Flickr
slam.poke.drop.tuck.dope
