obd2 to obd 1 distributor quesiton
Old Nov 11, 2007 | 02:24 PM
DC2Integra's Avatar
Default obd2 to obd 1 distributor quesiton
If i get a conversion harness for obd2 to obd1, and i need to get a new complete distributor, what type should i be looking for, one that is for an obd1? thanks guys
Old Nov 11, 2007 | 02:39 PM
mooninmike's Avatar
hey i just put and obd1 lsvtec in to my 2000 honda civic which is obd2. i used the obd2 harness and ecu to wirein the sensorsand shit and to control the injectors as far as the ignition i got a msd blaster ss coil pack and a msd distributor those wired in .if you use a obd1 ecu you need a jumper harnes so your best bet ie cheaper is just use the obd2
Old Nov 11, 2007 | 02:41 PM
mooninmike's Avatar
i didn t do the wiring i had a shop do it b/c i suck at wiring but thats what i used
Old Nov 11, 2007 | 02:42 PM
DC2Integra's Avatar
will there be any effects at all? or will it run perfectly fine?
Old Nov 11, 2007 | 02:51 PM
mooninmike's Avatar
mine is running greatand by using the obd2 ecu it allows me to use my vafc
Old Nov 11, 2007 | 02:52 PM
mooninmike's Avatar
what motor are you swapping
Old Nov 11, 2007 | 02:55 PM
DC2Integra's Avatar
i'm not swapping nethiong...i have a 2000 gsr, but converting my ecu from obd 2 to obd 1...but i need a new distributor and i was alittle confused on what i should be looking for cause my distributor is bad.
Old Nov 11, 2007 | 03:00 PM
mooninmike's Avatar
well if you are converting thewhole system ..... idont know why you would want to do that but okay . then you have to buy everything jumper harness obd1 ecu and an ignition sytem
Old Nov 12, 2007 | 05:39 AM
carobmor02's Avatar
Default obd2 to obd1
you don't need to replaced the distributor i have the same setup im running obd2 distributor
