rotor loose on dizzy???
Old Oct 21, 2007 | 12:21 PM
JoKiE crx4294's Avatar
popeye built!
Default rotor loose on dizzy???
If The Rotor Is Loose On The Shaft Will The Car Shut Off If You Rev It Up? The Car Will Idle But It You Try To Rev It Up It Shuts Off Like It Looses Spark Or Something. Does The Rotor Have To Be Tight On The Shaft For The Car To Run Properly? I Lost The Original Rotor Screw And Found Another But It Wouldnt Tighten All The Way
Can't spell strength without tren
AAS...It's whats for dinner
Old Oct 21, 2007 | 12:22 PM
-OneFastREX-'s Avatar
Growe Motorsports
ecu throwing any codes? maybe your map sensor
Growe Motorsports Racing
C.T. Photography
REP IS ALWAYS APPRECIATED AND RETURNED!
Old Oct 21, 2007 | 01:00 PM
popeye built!
Well The Car Didnt Start Turns Out The Coil Was Bad So When I Was Putting The Dizzy Back Together I Dropped The Rotor Screw And Lost It. So I Tried Making This Other Screw Work But It Wouldnt Tighten So The Rotor Sits On The Shaft Loose. No Codes And Map Is New
Old Oct 21, 2007 | 01:03 PM
Growe Motorsports
iight...so problem fixed?
C.T. Photography
Old Oct 21, 2007 | 01:28 PM
rangcrx's Avatar
engine building &best
GET A NEW SCREW!!!!!!!!!!!!!!!!!!!!and it will make the car seem like its backfireing may even run at low idel but when you try and rev it,it will pop and crap out
i love AUTOZONE
Old Oct 21, 2007 | 04:33 PM
popeye built!
Car Is Fixed. Just Needed The Right Screw
Old Oct 21, 2007 | 04:37 PM
rangcrx's Avatar
wow congrats and the socket is out?so glad all is good for you just be nice with the car and it will do the same
i love AUTOZONE
Old Oct 22, 2007 | 08:39 AM
popeye built!
no socket is still in there, thats were you come into play rangcrx
Old Oct 22, 2007 | 09:59 AM
rangcrx's Avatar
heheh well let me know i got no motorbuilds right now so im just bored all day!!!!!!!let me know
i love AUTOZONE
