wiring help!!!
Old Sep 26, 2007 | 07:58 PM
oldandbusted's Avatar
Default wiring help!!!
problem solved.
Old Sep 26, 2007 | 08:28 PM
sillywhips's Avatar
i had the same problem once and all it was was i forgot to hook up the thermostat ground so check that it might be it
shared_pm me if you need any honda swap or repairs done or welding done. in car engine rebuilds in a day like a boss
Originally Posted by rangcrx
trust me the girls like it black
Old Sep 26, 2007 | 09:29 PM
where does it connect at the thermostat and where else.
Old Sep 27, 2007 | 05:55 PM
BIGDADDY1's Avatar
also check ground on the starter.
Old Sep 27, 2007 | 06:28 PM
sillywhips's Avatar
it connects to the thermostat housing with a 10mm bolt there should be asmall ground wire coming out of your harness right in that area lmk if that helps matt
Old Sep 28, 2007 | 05:54 PM
thanks casey that was the problem.
Old Sep 29, 2007 | 08:19 AM
sillywhips's Avatar
no problem glad i could help
