need help!!!! i got a tranny problem
Old Sep 21, 2007 | 03:42 PM
rotacb7's Avatar
Default need help!!!! i got a tranny problem
what up tr i got a ef hatch with a b18b1 and b16 cable tranny.i was driving today at around 3:30 at speed limit and when i press down on the clutch to shift into fourth i felt sumthing pop and it wont go into any gear now...i checked the tranny cable and its not that...and now the clutch lost almost all its pressure...any helpful information would be very appreciated...thank you
Old Sep 21, 2007 | 04:05 PM
freakasis's Avatar
its gotta have somthing to do with the assembly that attatches the clutch cable to the fork. dont know what its called.....watch it while someone else pushes in the clutch....your problem should be obvious if its there.
Old Sep 21, 2007 | 04:09 PM
rotacb7's Avatar
thanks man ima go check as soon as the rain stops....what fork are you talking about though???
Old Sep 21, 2007 | 04:14 PM
freakasis's Avatar
the fork that pushes on the pressure plate....basically where the cable attatches to the trans..or mayve that plastic adjuster piece mounted on the trans. its part of the clutch cable assembly. that couldda broke too.
Old Sep 21, 2007 | 04:17 PM
rotacb7's Avatar
ohhh ok thanks again man...ill let you know how it turns out
