Valve adjustment w/Toda Spec B
Old Sep 27, 2000 | 03:06 PM
S&P500Si's Avatar
What should the proper adjustment be with these cams?
Old Sep 27, 2000 | 05:41 PM
Enthalpy's Avatar
TR Balla Donor Supreme
are these by any chance in a Black 99-00 Si??
Cause if so then i met you over at spec r one day. kenji would be the best person to talk to about this. I assume you have his Number b/c you bought one of his harnesses. he is also on this list. If you dont get an answer on this forum put an Attn: Kenji post up in import news...
[This message has been edited by Enthalpy (edited 09-27-2000).]
Old Sep 27, 2000 | 07:02 PM
Enthalpy's Avatar
Perhaps you should check in the box that they came with for a spec sheet. As far as I know the valves should be adjusted to stock if using a billet cam. Valve lash on the other hand is a different story. Dig up that spec sheet boy
-JG-
Also known as John from Spec R
Honda S2000
1988 CRX
Visit my homepage!
Old Sep 28, 2000 | 03:53 AM
S&P500Si's Avatar
No sepc sheet but I will search around to see what I can dig up. Thanks!
Old Oct 7, 2000 | 07:14 AM
kenji's Avatar
With all Toda cams you adjust the valves to:
intake 0.2mm
exhaust 0.2mm
-kenji
