tire pressure Q's
Old Sep 15, 2007 | 07:38 PM
jojo69's Avatar
Default tire pressure Q's
For a 92 Hatch, daily driver, running HX's and Yoko's AVS ES100, what tire pressure should i go for optimally?
Recommended ones (from the manual) is 32 psi all around. Max psi is 40 on tires.
I was thinking of trying something around 34-35 psi when cold...
what u all have? What do you'all recommend?
thanks
Old Sep 15, 2007 | 10:47 PM
custom240sx's Avatar
DC Crew Member #1
I run 25 psi in front and 42 in back...the tire pressure on my side wall is max 50...they are kumho ecsta ast...just go about 5 under on rear and about 10 under on front I.E. 30 front 35 rear...should be fine.
Old Sep 16, 2007 | 07:13 AM
Gixxer's Avatar
Hide your daughters
+1.
Old Sep 16, 2007 | 10:04 AM
jojo69's Avatar
why do u recommend lower in front and higher in back? i mean, what's the reasoning behind it? and why not all around same presure?
just curious....
Old Sep 16, 2007 | 03:18 PM
DC Crew Member #1
The front will hook up a little better with lower psi and the rear will squat less on a launch because it will be a little stiffer with the higher psi.
Old Sep 16, 2007 | 04:24 PM
jlude90's Avatar
aspiring luder
yeah, he was talking daily
the lower you run, the worse your furl economy, and hard cornering will improve to a point, but too low will really screw you
the higher, you get less traction, but better fuel economy
Old Sep 16, 2007 | 04:41 PM
DC Crew Member #1
I get over 30 mpg daily with 25psi front and 42 rear on a ls with ls tranny.
Old Sep 17, 2007 | 01:46 PM
jojo69's Avatar
Originally Posted by Gixxer
+1.
Is that cold tires or hot? I'm just gonna start with that (30 in front-cold & 34 in rear-cold) and see how it handles...
any others wanna giver input on this?
thx
Old Sep 17, 2007 | 02:10 PM
nolexforever's Avatar
for a daily driven car on the same tires, i run 36/34 cold psi.
