what would cause bogging a low rpms?
Old Sep 2, 2007 | 04:41 PM
MazdaMX3Freak's Avatar
Vtack THIS!!!
Default what would cause bogging a low rpms?
okay im gonna try asking again .....my car is bogging down like it has no power in low rpms only 0 - 3000. and only when it is in gear......when its in neutral it revs fine and very responsive.
And all the sensors are fine also there are no IM/TB leaks!!!
-2008.5 Mazdaspeed3 CWP
Old Sep 2, 2007 | 04:49 PM
JR.'s Avatar
JR.
my car does the same shit, but its because it has an LS tranny.
98 talon awd automagic
Old Sep 2, 2007 | 04:56 PM
Vtack THIS!!!
the motor is a jdm d15b /w stock d15b tranny.....any other ideas
Old Sep 2, 2007 | 06:29 PM
nocomply540's Avatar
is retired...
check your fuel filter, spark plugs, wires, dizzy...I dunno bro thats a tough one. I'd personally start with a new fuel filter then go on from there...
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
Old Sep 2, 2007 | 07:47 PM
Vtack THIS!!!
yeah spark plugs, fuel filter,wires, o2, cat, and all sensor are new and bought at time of swap.....so could it be somthing with tuning maybe? or sience it does it when its only in gear somthing to do with the clutch? forgot to add has a 9lb FW and 6 pluck clutch........
Old Sep 2, 2007 | 08:58 PM
sleepinsol's Avatar
starting over
try checkin the grommets in the valve cover for the plug wires. if theyre not sealed right water/oil can get down in there where ur spark plugs are n cause it to bog a lil. myne did that too (especially on humid days). i pulled the valve cover off n the wires out. cleaned the wires n put the grommets back in with some silicone n was good to go after that. use some wd40 to get the water off the wires (if there is any) and get some brake clean to skwirt down into the holes there to get rid of any oil that mite b in there.....if this isnt the case then im stumped on this one....but it sounds like something to do with the ignition system.
Old Sep 5, 2007 | 04:52 PM
~totaled2many~'s Avatar
when this happened to my gsr, the wiring harness was the culpret
Old Sep 5, 2007 | 06:09 PM
mtber's Avatar
Is the vehicle throwing any codes ? (check engine light)
If so, what codes ?
Old Sep 5, 2007 | 06:56 PM
nolexforever's Avatar
check the distributor timing.
