93 del sol si stumbles at idle
Old Aug 26, 2007 | 05:04 AM
redcoats1976's Avatar
Default 93 del sol si stumbles at idle
ive got a 93 del sol si,stock d16z6 automatic.when its hot and the car has been running and is shut off for about 10 minutes it misses for about 15 seconds at low speed,then clears up and runs fine.has new plugs,wires,cap and rotor.any ideas?
Old Aug 26, 2007 | 11:02 PM
sxecrow's Avatar
EG2 CRX
what are you saying? I am teh lost with your question.
Old Aug 27, 2007 | 03:08 AM
its like heat soak,you put it in gear after starting it up and it drops cylinders(misfires) for about 20 seconds...then it runs fine.also has had new fuel filter.possibly the fuel pump is getting weak?it doesnt do it when its cold
Old Aug 27, 2007 | 03:21 AM
mtber's Avatar
Is the check engine light on ?
If so, check the codes & get back to us.
Old Aug 27, 2007 | 09:36 AM
no check engine light,and other than the first 20 seconds of operation it runs just fine.only drops cylinders when it is warm and restarted after sitting a few minutes. the car has approx.165k miles on it and is still running original equipment sensors and computer,nothing has been changed.
Old Aug 28, 2007 | 12:40 PM
ekhatchboy's Avatar
Redrocket part 2
check your oil it could be a bad head gasket usually the car will start fine till it heats up. also there is a trick to find out by opening the radiator cap and when its on if it spews out its a bad head gasket or something?! someone correct me on that please. lol good rep is accepted thanks
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Old Aug 28, 2007 | 02:23 PM
no milk shake on the dipstick...BTW whats up with this rep and how do i give rep???
Old Aug 28, 2007 | 02:29 PM
ekhatchboy's Avatar
Redrocket part 2
click the scale on the bottom of my post below the gallery. then click positive rep and give details on reason for good rep
Current Cars
