People with guages... need help.
Old Aug 18, 2007 | 07:57 PM
Si-R Trickey's Avatar
The most interesting man
Default People with guages... need help.
Anyone that has installed guages (electrical or mechanical), I got a couple of questions. I got a oil pressure and a water temperature gauges, both are electrical. Where do you put the sending unit for the water temperature at? I heard it is on the back of the head (B16a1) where there is a already plugged hole... is this right? If so, what is the exact size and where can I pick up the meteric fitting adapter for this?
Kinda the same thing for the oil pressure. I heard that it is located next to the oil filter, is this right as well? If so what is the size for the meteric adapter and where can I get this as well? Any help would be much appereceated.
Old Aug 18, 2007 | 10:24 PM
mug's Avatar
mug
Hey Mr Toilet Im The Shit
Oil its for a mech but it shows location/Size
Honda-Tech.com: Honda Civic/Del Sol (1992 - 2000): DIY: Manual oil pressure gauge install
Heres a little about the water temp kinda mixed on this depending what you are looking for.Also the temp switch is under your dist. I belive its a white plug but dont hold me to it.But hope it helps.
Honda-Tech.com: Honda CRX / EF Civic: Autometer Water Temp Sending Unit [Electric]! Help me!
Old Aug 19, 2007 | 07:28 PM
Thanks a lot!
Old Aug 19, 2007 | 11:24 PM
nocomply540's Avatar
is retired...
Another thought...you could just tap into your cooling hard line on the back of the block for the water temp!
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
Old Aug 20, 2007 | 08:41 AM
Did you do that? How acurate is that? My factory temp guage in my cluster goes stright to the H (hot) as soon as I turn on the car. Thats one reason why I am hooking up guages.
Old Aug 20, 2007 | 09:27 AM
amimaxima's Avatar
are those g35 rims on your car?
Old Aug 20, 2007 | 09:55 AM
Yes.
Old Aug 20, 2007 | 01:08 PM
is retired...
unplug the sensor ont he back of the block and if the needle goes down it's the sensor which it really sounds like
