GSR problems...need some opinions
Old Aug 16, 2007 | 06:59 AM
BLK94EGCOUPE's Avatar
some nissan
Default GSR problems...need some opinions
Ok I have a GSR in a 95 EX it has this crazy idle surging witch ive had on previous hondas but I tried to clean the FITV and that didnt work so im lookin around the engine bay and see the IACV is unplugged so I plug it in and start the car but then its starts and goes straight to 3K and holds and then drops and back to 3K but when you unplug it it will just bounce 1000k-1500K really fast,also I noticed it has a test pipe with no 02 sensore bung so there is no 02 sensor so I believe this maybe contributing to the problem but i dont know where to start and dont want to buy sensors and stuff im not gonna use any help would be appreciated and i'll pass some good ol' rep
Old Aug 16, 2007 | 07:15 AM
Gixxer's Avatar
Hide your daughters
Yep sounds like you need to buy an O2 sensor and have a bung welded in.
Old Aug 16, 2007 | 07:23 AM
01LatinVizionGSR's Avatar
why dont u check the whats amps the tps is showing and go from there its most probably a faulty tps but or a vacumm leak. the tps should be at .45 at idle.
Old Aug 16, 2007 | 07:35 AM
rangcrx's Avatar
engine building &best
if it goes to 3K when you plug it in your have a vac. leak some where or your throttle body is open...without a O2 in a Eg you car will idle lil lower and if its a aftermarket header and the o2sensor is not right in the top of the manifold it will run rice and very low idle
i love AUTOZONE
Old Aug 16, 2007 | 08:53 AM
some nissan
thanks I just swapped throttle bodies and its still doing it and I check all the vacum lines even on that back of the intake manifold..anything else maybe?
Old Aug 16, 2007 | 09:06 AM
rangcrx's Avatar
bad pcv valve
i love AUTOZONE
Old Aug 16, 2007 | 11:27 AM
some nissan
checked pcv valve it throwing code 2 long 3 short which is the knock sensor but would that make it idle crazy.
Old Aug 16, 2007 | 11:56 AM
rangcrx's Avatar
hmmm ask mtber about that or Kj cause that i dont know
i love AUTOZONE
Old Aug 16, 2007 | 02:44 PM
Gixxer's Avatar
Hide your daughters
Hmm knock sensor wouldn't make it idle bad, I still think it's a vacuum leak somewhere.
Old Aug 16, 2007 | 06:26 PM
mtber's Avatar
An o2 code is not going to make it idle like you are describing.
It sounds like the fitv is leaking... take your intake off and put your thumb on the fitv port on the bottom of the throttle body when the car is idling.
If this is not the issue then you have a vacuum leak elsewhere.
Code 23 will also not make the car idle nuts.
You can disable the o2 and code 23 for knock by having your ecu chipped.
