h22 in my civic?
Old Jul 26, 2007 | 03:33 AM
monkey_racing's Avatar
Exclamation h22 in my civic?
im thinking of doing a swap and in know how much a b series cost so im thinking of doing a h22 swap. i have a 92 honda civic 4dr. wat will i need for the swap? how will it fit in. is putting it in harder than dropping a b series?
Old Jul 26, 2007 | 05:00 AM
DemonCivic's Avatar
h swap is more expensive and requires a lot more than a b series
Old Jul 26, 2007 | 06:19 AM
PooN_Lude's Avatar
What do you need for the swap? Research. Honda-Tech.com: Hybrid: [FAQ] ***H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here***
How will it fit? if you get a decent mount kit, i recommend the Hasport EGH2 mounts, it will fit like a glove.
If you have done a motor swap before you should have no problems putting the h22 in, it is much easier than some people make it out to be. A few wires will be extended and you need to cut out holes for the shift linkage and the frame rail for the tranny if you use a jdm lsd tranny.
I have put an h22a in my EG Sedan, pm me if you have any questions.
Old Jul 26, 2007 | 06:44 AM
ok thanks. im just soo tired of d15. i might go gsr too
Old Jul 26, 2007 | 01:25 PM
Hybrid_eg's Avatar
i like the blue ones
Hasn't this been covered at least 3 times in this month alone? Admins in here are sllllllaaaaacccckkkkinnnnggggg.
USE THE SEARCH BUTTON
AND READ THE FAQ!
Shut yo ass up nugguh..
ReginaVagina
Old Jul 26, 2007 | 03:01 PM
dropcivic's Avatar
Redneck Proud
h2b kit, solves the hole in the floor problem with better gear ratios.
Honda certified Tech
Southern Pride not racism
