Help Pleaseee With My 2000 Honda Civic Si
Old Jul 21, 2007 | 11:49 AM
ldizzle81's Avatar
Default Help Pleaseee With My 2000 Honda Civic Si
Im Am Having A Troule Code Of P1337 Cranshaft Speed Fluctuation Sensor No Signal I Have Everthing Plugged In Just Recently Swapped Engines And This Is The Trouble Code Im Getting. Could This Sensor Be The Reason Why My Car Will Not Idle And Run Like A Pos. Please Serious Help Only Ive Been Ripped Off And Spent Alot Of Money On This And Just Need A Little Help My Engine Is A B16a2 Thanks Jeff.
Old Jul 21, 2007 | 12:28 PM
dantamparacer's Avatar
bottle fed is best fed
If you dont mind me askin why did you change engines in the first place... is this the same problem you were having? Did you use the same distributer because I believe that the sensor is in the distributer
but I am not sure.
Old Jul 21, 2007 | 12:35 PM
ldizzle81's Avatar
No I Had To Switch Engines Because I Blew My Last One The Engine That I Bought Came Bare Bones I Had To Use Just About Everything Off My Last One And I Thought That That Sensor Is Down By The Oil Pump
Old Jul 21, 2007 | 12:50 PM
nocomply540's Avatar
is retired...
I just did a search for crankcase fluctuation sensor over on Honda-Tech for ya but come up empty. By the sounds of the sensor sounds like it would indeed make your car run like crap. Take a mulitmeter to the wires running to it and check to make sure you have power going to it. If there's power going to it try replacing it. I dunno...I'm obdo....I'm just trying to use basic common knowledge. Let us know how it works out.
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
Old Jul 21, 2007 | 01:22 PM
ldizzle81's Avatar
Will Do Thanks For Your Help
Old Jul 22, 2007 | 02:10 PM
is retired...
any updates?
Old Jul 25, 2007 | 03:51 PM
ldizzle81's Avatar
no luck yet i finally put it in the shop it should be done today i will let you know
Old Dec 20, 2007 | 12:27 PM
alexaaa's Avatar
Default I am also Having the P1337 code on a 2000 civic SI
Does anyone have an idea on the P1337
thx,
