2000 si help !!!!!!!!! AGAIN!!!!!!!!!
yet another problem, the black wire that is running to my main relay was not hooked up to anything. i grounded it with the yellow coming out of my main relay and i got power to the main relay, ok this is were im having a big problem, the black wire is getting really hot?? and my fuse box(under-hood) smells like burning wires!!! now my starter is not even clicking, nothing; all fuses are good!! THANKS
You fudged it up good didn't you? Call (813)842-5517 ask for Neal. That would be the easiest way to fix your car. Then just stop messing with it.
Shut yo ass up nugguh..
ReginaVagina
ReginaVagina
you need to cheak circuit breakers and other relays, but you should give neal a call if you need it done soon. if your trying to fix this yourself you might want to get a good multi meter and test the circuit you are having problems in
Just got my 20th car and damn its so clean.
So....Lemme get this straight, You just saw a wire hanging out and decided to connect it to something?
Not a smart Idea, Give up Modding cars now before you hurt yourself.
Call Neal, Have him fix it (I hope he charges you an outragious price so you learn your lesson), Then just DRIVE the car.
G/L with your little hangup
yeah it was just hangin there!!!!! and there is no were for it to plug in the main relay plug! thanks 89to90 for your advice! THANKS
talking shit, really does not help.
bro go buy a haynes manual. look at all the pictures and try and match everything up like it looks in the picture. don't just "freestyle" it, you could end up hurting it more then helping... or call neal, he never hurts....
its coming...
its coming...
Sorry for the BS post, I was just feeling a little spunky at the moment I read your problem.
Anywho.............There are several wires under the dash that hang loose, They are there for OEM Options like fog lights, Upgraded OE stereo equipment, heated seats, power folding mirrors, etc.....
Did you double check all of the fuses and blocks under the hood in the engine compartment fuse box?
Make sure none of those are blown.
But start by disconnecting that wire that you just randomly hooked up.
Honda-Tech.com: Honda Civic/Del Sol (1992 - 2000): ek wire diagram
Automotive Wiring Diagrams 1984-2006
or if Neal isn't available, Contact John Vega at phearable.net , He should have the right diagram for you to scope out and identify that wire.
-Jeff
-Jeff
