Delsol Si Swap-- B16 also cable Trans???
Old Jun 23, 2007 | 07:25 PM
Snowblaizer's Avatar
Default Delsol Si Swap-- B16 also cable Trans???
I have a single cam V-tec Delsol that I would like to change to B16. I have done a swap in a Delsol a long time ago with a friend where we put a b18c in it. However I did not help them switch the tranny around. So here is my question how hard is it to change tranny from Hydraulic to Cable and can anyone explain what I will have to do, because I hate having to bleed my damn clutch all the time and its just a pain in the ass all around. Also if know please list all pts I might need for complete swap if you know or have done one before. Thanks alot.
-Snowblaizer
Old Jun 23, 2007 | 09:16 PM
mtber's Avatar
Hyrdro trannys do not require you to bleed your clutch all the time as you are saying they do.
I would recommend you stay with a hydro tranny as that is what is in your vehicle now.
You will need a dohc vtec delsol rear motor mount bracket & a/c compressor bracket to keep a/c.
I recommend you do some research: http://hondaswap.com/ Honda-Tech.com: Main Forum List and use the SEARCH button.
Old Jun 27, 2007 | 09:44 AM
1BADP71's Avatar
E & I Certified
cable transmissions never came in sols and would require a bit of fab work . more pain than its worth . sell your cable trans and buy a hydraulic one.
Old Jun 27, 2007 | 11:22 AM
Old Renegade's Avatar
Cool Runnings
i would stay with the hydro if i was you, to me it would be easeir to bleed the hyro clucth than to adjust and finely adjust a cable tranny in most cases in my opinion.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
