crx b series turbo HOW TO MAKE IT A/C COMPATIBLE
Old Jun 13, 2007 | 11:43 PM
Eluzzionz's Avatar
Default crx b series turbo HOW TO MAKE IT A/C COMPATIBLE
basically right now i have an lsvtec crx built for turbo..got a full turbonetics kit with log style manifold...my question is..can i make a/c work with this?...
if so what do i need to do..right now i have the full length radiator which i understand id have to get the half sized plus thin fal fan or something..do i have to get a different manifold? 3" dp compatible? or do i need 2.5" dp...
also what a/c components do i get..crx a/c then a b series bracket? and whats all included..compression lines condenser anything else im missing..thanks(its really f'ing hot out and i want a/c more then anything..i use to not care as long as the car was fast but im over that shit..comfortable cool(a/c) then fast)
thanks for all the help.
Old Jun 14, 2007 | 09:34 AM
Eluzzionz's Avatar
nobody knows?!?!?!..ive asked a similiar question before and never got answered. Where's the professionals at?
Old Jun 14, 2007 | 09:55 AM
KJ's Avatar
KJ
bored at work
Turbonetics kits are A/C compatible on 92+ civics and 94+ tegs.
Crx's are a whole different story. It definitely can be done, but you won't know what is necessary till you actually start putting things together. My advice would be to get the A/C swap mount and use your d series compressor. You will probably need custom lines made to clear the turbo stuff. You will definitely need slim fans for both the condenser and radiator. You should be able to use the full length radiator if you recirc the dumptube. Probably need to stick to a 2.5" downpipe.
Old Jun 14, 2007 | 10:36 AM
Eluzzionz's Avatar
thanks man i had a feeling ud chime in with ur fab skills hehe...
so what mount do i use..i know nothin about puttin a/c on the b series in the crx..so im lost i do know i need everything and someone to install it.
thanks for the help...
Old Jun 14, 2007 | 10:42 AM
KJ's Avatar
KJ
bored at work
I've done a/c in a ef several ways.
First way was with a stock 90 ls bracket and 90 ls compressor and custom lines. This worked well but we had to notch the cross member to clear the a/c compressor.
Second way is to buy the hasport or HCP a/c mount that adapts the d series compressor to the b series motor. This uses the stock lines and also works well.
In your case I'd say to use the civic compressor and custom mount bracket because it takes up less space. I still think the lines will need to be custom becasue of the routing required to clear the turbo stuff.
Old Jun 14, 2007 | 10:45 AM
Eluzzionz's Avatar
thanks... how/where do you get custom a/c lines
my plan is to not turbo my car just yet..instead im trying to find a nice clean crx/civic shell and swap my engine/suspension in it...get the a/c going and then get the turbo installed..cuz im hurt on money i think i explained that when i pmed u before..so im trying to get a job n get back up and going..
tried to rep but it said i have to give rep to others before i can rep u again?!?!?
Old Jun 14, 2007 | 10:53 AM
F4A22's Avatar
Old School
Amazon hose is your friend.
Old Jun 14, 2007 | 10:55 AM
Eluzzionz's Avatar
woohoo..my roommates aunt works there..cost for me..
rep to u..if it lets me
Old Jun 14, 2007 | 01:00 PM
MrLHT's Avatar
John @ LHT Performance
Here's a B20Vtec CRX we did. It uses a LHT manifold and 3" down pipe, it also has a full size radiator. It's very tight but can be done.
Here's the link.
1988 CRX Si w/ Turbocharged B20 Vtec
www.lhtperformance.net.
727 344 1800
*Turbocharging* Engine building* Tuning *Intercooler piping*exhausts* headers* clutches ,fabrication and much more
13 years in the same location.
** HONDATA Authorized Dealer+ Tuner **
01 Type R-647whp street car w' AC - Cover of turbo magazine Feb 2008
01 K20a INSIGHT - Cover of Honda Tuning magazine June 2008
2011 KR-Z K20 powered CR-Z -Cover of Honda Tuning magazine April 2011
Old Jun 14, 2007 | 01:12 PM
Eluzzionz's Avatar
now that is BEAUTIFUL...i wish i could afford something like that...
i know ive talked to you before about turbo piping which i know would be done right..and look good..but then id have to have a turbo manifold built as well..do u guys make the b series brackets instead of buying one for the d series compressor?...also like i said if i could have you guys do this..i could get the hoses for the a/c at a discounted price for knowing someone who works there..i might talk to you about this and see what kind of price it would cost..thanks josh..
