air fuel issues
Old Jun 7, 2007 | 06:14 PM
juicinrexls87's Avatar
Default air fuel issues
okay heres my problem i have no way to read air fuel since i have no o2 sensor and when my car heats up it must get a wack reading how do i just bypass the o2 readings in the ecu to make my car think its all better? and wheres the ecu jumper to read my check engine codes on a 89 crx
Old Jun 7, 2007 | 10:17 PM
Old Jun 7, 2007 | 10:53 PM
CRXkid24's Avatar
uh oh
there should be a red blinky light. refer to the FAQ.
my car gets mad after 5,500 rpm!
cheeSpec tuned!
R.I.P.
Pablo
Lil John
Mario
Old Jun 8, 2007 | 08:26 AM
where can i find this ?
Old Jun 8, 2007 | 12:58 PM
Old Jun 8, 2007 | 03:46 PM
mtber's Avatar
I am guessing your car is obd0.
If it is, on the passenger side floor under the dash, there will be a plate under the carpet with a whole in it. There will be a red LED that flashes codes. You do not need a jumper to check the codes on the obd0 vehicle.
Concerning the o2 sensor, you can only disable the o2 sensor by removing it in your engine computer's programming. This would require you to have your computer socketed/chipped.
Old Jun 8, 2007 | 05:22 PM
pm'd ttt
