hmm???help?0BD1 ON 0BD0 HEAD...???
Old Jun 4, 2007 | 08:27 AM
lilneedle's Avatar
DA SHIFT SUPERVISOR!!!
Default hmm???help?0BD1 ON 0BD0 HEAD...???
I was thinking bout using a 91 crx si head with my build....I want to go obd0 though....I have a z6 intake and tb...think I can use the obd1 dizzy???will it bolt to my head...I am trying to go obd1 non vtec turbo....help....plus any other pointers on getting this to run in a crx or ef....thanx....Tom
Im comming
Old Jun 4, 2007 | 12:41 PM
rangcrx's Avatar
engine building &best
z6 intake is strang in the way of fastidelsensor not sure it goes with the crx head i know the Dx eg manifold is the same line up i would make sure i change out the valve springs on that crx head just knowing they have more then 150K and 17years of ware is my 2cents
i love AUTOZONE
Old Jun 4, 2007 | 02:07 PM
SmokinS13SR20's Avatar
That ginger...
The distributor doesn't really line up correctly, but you can get 2/3 bolts into the head.
Don't use the OBD-1 z6 distributor.
What you should do is run the D16A6 distributor and use this...Rywire - Online Store
Old Jun 4, 2007 | 02:28 PM
EclipseTurbo94's Avatar
well
Old Jun 4, 2007 | 05:33 PM
lilneedle's Avatar
I still need to know for sure weather or not I can use a obd1 dizzy on my a6 head...my ojective is to run any d16 block with my non vtec a6 obd0 head with a obd1 ecu....so any help would be much appreciated...thanx...Tom
Im comming
