Tell me about the F20B
Is it worth it to go with f20b over h22 in a 94 accord lx? will it be a direct replacement, meaning axles, linkage, mounts, etc.? how much do the swaps generally run? If i got one, would it need to be resleeved? how hard are the parts to get for it? any and all info would be great, thanks in advance.
-Ross |
Go with the h22a. More displacement, same hp.
I think it would be your best interest to go with h22a, cheaper, more information out about it and replacement parts are more easily accesible. Plus i think the h22 makes more tq. which will help you pull around a heavy accord a bit easier. the f20 does bolt right in, but remember its obd2, so you'd have to get do the odb2-obd1 wiring
so the h22 isnt a direct bolt up? i want to get as much info about both swaps b4 i decide..........so any and all info is great!
yes. it bolts in
Might want to look into this thread!
https://www.tamparacing.com/forums/h...ld-how-do.html Should answer most of your questions. That thread is still floating around right below this one you just had to look |
ya i already went thru that whole thread and absorbed all of it. these questions i have now came up when i was reading it.....those guys change motors like i change underwear....lol they are always doing something different and sharing their findings which is cool! also i am wondering will all my plugs on the f22b2 motor plug into an h22a, i think i will go h22......
Originally Posted by technoracer
(Post 4231156)
the wiring should be roughly the same, you may need to extend some wires, and if you have the non-vtec motor you will need to add the wires for vtec...but its a pretty straight forward swap. good luck |
thank you all for info...rep given
Retuned!
