96 accord NEED HELP!!!!!!!!!!!!!!
Old May 24, 2007 | 02:53 PM
nomad's Avatar
Default 96 accord NEED HELP!!!!!!!!!!!!!!
i went to change the plugs on the car. when i pulled out the boot it was covered in oil!!!
do in need to replace the valve cover gasket??
96 Accord Lx
Old May 24, 2007 | 02:56 PM
casanova1514's Avatar
civic97
dont belive it's the gasket sound more like u rings if the gasket was done u would have coolant on the spark plugs also hows the car running is it smoking i bet it is
Old May 24, 2007 | 03:05 PM
nomad's Avatar
no it's not smoking at all.
it's the outside of the boot
Old May 24, 2007 | 03:17 PM
retro's Avatar
why are you tracking me?
yes...4 round gaskets on the valve cover for the plug holes...common
Old May 24, 2007 | 04:22 PM
Vcruz's Avatar
Its ur valve cover gasket rings 4 sure they should have came with the valve cover gasket
Old May 25, 2007 | 12:55 AM
nomad's Avatar
thanks for the help
Old May 27, 2007 | 09:50 AM
accordsm's Avatar
its the rings cuz same thing happend to my moms car
Old May 28, 2007 | 10:23 AM
I cuncur with the oil leak/new valve cover gasket solution.
Old gaskets get heat hardened. Use Red high temp gasket sealer on the new gaskets. Aluminum valve covers hold the gasket better.
Post up what you find.-Bob
