Ecu Question
Old May 8, 2007 | 08:19 AM
Yellow Rocket's Avatar
The Big Diehl
Default Ecu Question
I Have A 91 Crx Dx With A D16a6 In The Car (89 Block 93 Head), What Ecu Should I Be Using With This Swap? Its All Obd0 And I Am Currently Running A Pm6 Ecu And I Was Just Curious If Its The Right Ecu. Any Help Would Be Appreciated.
They say when a shark attacks you're supposed to punch him in the face. Then what, poke him in the eye with your nub.
Old May 8, 2007 | 08:24 AM
Derka's Avatar
TR Balla Donor Supreme
that should be fine.
1998 crv daily beater
Old May 8, 2007 | 08:39 AM
The Big Diehl
Its Just That The Car Runs Is Running Kinda Funny, Almost Like Its Getting Too Much Fuel. I Changed The Cap And Rotor And New Plugs And Wires But That Didnt Help Any. Im Just Really Confused The Only Code Its Throwing Is The Vss.
Old May 12, 2007 | 10:38 AM
lilneedle's Avatar
DA SHIFT SUPERVISOR!!!
obd0 in 93?huh?92 they started obd1 right?what head do you have on that 88-91 A6 block?thats the only years they were made I think...
Im comming
Old May 12, 2007 | 03:19 PM
The Big Diehl
the head is a 93 the block is 89 its all obd0 wiring
Old May 13, 2007 | 06:06 PM
crxter's Avatar
crx dx? is it dual-point injection (funny looking IM)? or milti-point (4 injectors)? If its dual-point, it should be running the pm5 ecu, ideally.
Old May 13, 2007 | 08:23 PM
integrex's Avatar
check all of your timing and tps current.....should be the right ecu as long as your multi point...
