Need Help! Has anyone had the Fuse for the Condensor Fan keep Blowing? 1998 Civic EX!
Old May 1, 2007 | 07:51 PM
Viper4ug's Avatar
Default Need Help! Has anyone had the Fuse for the Condensor Fan keep Blowing? 1998 Civic EX!
Hey guys, well im stuck.... my first thought was a bad a/c condensor fan! Wrong! I replaced it and still the fuse blowes after the fan runs for a few secs! I am trying to fix this asap cause without the fan working, which blowes the a/c condensor fan fuse, which causes the compressor to stop working i cant get cold a/c! Please if youve had this issue already hit me up!
Call Me If You Have Any Questions Or To Make Me An Offer! Pm Me for My Number!
Old May 1, 2007 | 07:56 PM
mtber's Avatar
What kind of fan are you running on the system ?
Some aftermarket fans can draw a lot more then factory fans causing this issue.
If this occurs you should wire a relay to make the fans draw current directly from the battery.
Old May 1, 2007 | 11:37 PM
MAYMAY's Avatar
could be the ac harness wire...
that happened to me once..
i ended up replace the whole ac harness...
for my eg..there are the ac condenser and ac compresser
relay...but i dont think there is any fuse to the ac ssytem
but not sure about ek civic
Old May 2, 2007 | 04:43 AM
Viper4ug's Avatar
ty ttt ne other sugestions please post!
Old May 2, 2007 | 07:04 AM
Viper4ug's Avatar
relay didnt work now i get nothing
