To all honda gods... plz help.... if u can LOL!
Old Apr 11, 2007 | 08:09 PM
MazdaMX3Freak's Avatar
Vtack THIS!!!
Default To all honda gods... plz help.... if u can LOL!
Im swapping a B16a2 99 odb2b SI motor into my friends 95 Delsol DX. Heres what ive learned so far... the odb2b wiring harness only plugs into the Ecu /w 2 plugs and the other one goes to the fuse box? and a seperate plug from the cabin plus into the other ECU slot. Well i have neither the cabin harness or fuse box or can i get ahold of a odb2a wiring harness so... what should i do/ can i do? and dont give me some retarded BS answer b/c thats all im getting from half of you on here. I want an intellegent solution from someone who knows what there talking about plz! In other words if u dont know you shit then then shut your mouth! b/c i dont know that much about hondas and i finaly want a straight anwser.......THANX!
-2008.5 Mazdaspeed3 CWP
Old Apr 12, 2007 | 12:54 AM
Compare the 2 wiring diagrams, and run the wires that are located in a different spot, to the proper pin location, and plug them in.-Bob
Old Apr 12, 2007 | 01:00 AM
4door5g's Avatar
if you call johnvega at pheralbe he could chip your sohc ecu to work with that motor, your beter off staying obd 1 if you can
Old Apr 12, 2007 | 03:11 AM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
its phearable.net.
and the only reason odb1 is recommended is because you can tune it easier.
-Winston Churchill
Old Apr 12, 2007 | 11:12 AM
vonrobins's Avatar
love hondas ftw
its an easy swap, just get the mounts , toss it in , use the obd1 harness and trade someone that obd2 ecu you have for a obd1 ecu and your done or like they said get some one to chip your sohc ecu and grab a obd1 distributor also just to make it easier or cut the harness off of the sohc distributor you got and wire it up to the obd2 one ,,, thats just my advice
._________________________
Old Apr 12, 2007 | 11:54 AM
Vtack THIS!!!
thanx
Old Apr 12, 2007 | 06:12 PM
opiumdaze's Avatar
u need obd1 b series dizzy and obd1 injectors with the obd1 wiring harness for it to be plug and play basically... so disregard the obd2b si harness
Old Apr 16, 2007 | 04:00 AM
B18C14's Avatar
Spoolinfool
call me...
REPLACEMENT FOR DISPLACEMENT
