Writeup: 05 RSX DASH and K series swap in 95 Integra!
[B]I am doing a 05 RSX Type S K series engine swap and DASH Swap into a 95 Integra. I figured I'd do a writeup since I can't find any information on the web. If anyone knows of someone else who has done this, point me at a link ! I'd like to see it. As it stands, and to the best of my knowledge, this will be the first complete Integra to RSX conversion.
I will be doing this writeup as I go, so it may take a little time. The plan is to totally rewire a DC2 Integra (1994-2001)with 2005 rsx ABS, Airbags, AC, O2s, and COMPLETE working dash using 90% of the original RSX harnesses, and do a K series (Z1) swap with 14k miles with matching odo mileage! http://www.we-todd-did-racing.com/vi...l/999617_ixmec Week 1 The RSX has been stripped to the core, and scraped. I kept the front clip for now because I will chop a section of the RSX firewall to put in the DC2 to fit the AC box. http://www.we-todd-did-racing.com/th...s/102_2157.JPG At this point I have an empty engine bay on the DC2 and the dash/engine bay/ecu harness has been removed. Everything will be removed and as much stuff as possible will be replaced with RSX componets. http://www.we-todd-did-racing.com/th...f/102_2140.JPG I cut the wires on the passenger door about a foot into the vehicle. I believe there are 15 wires in that door. I will wire the doors together using just the door wires from the Integra harness.http://www.we-todd-did-racing.com/th...q/102_2141.JPG I will take progress photos and let you guys know what I run into. I have a few issues that I know may be a little tricky, but how hard could this be.....right? http://img.photobucket.com/albums/v3...h/102_2142.jpg Above: Stock Integra interior firewall. (BEFORE) http://img.photobucket.com/albums/v3...h/102_2146.jpg Above: Stock Integra interior firewall. (BEFORE) http://img.photobucket.com/albums/v3...h/102_2160.jpg RSX Interior Firewall FOR REFERENCE http://img.photobucket.com/albums/v3...h/102_2248.jpg RSX interior firewall again to compare with teg firewall below. http://img.photobucket.com/albums/v3...h/102_2225.jpg REAR OF RSX DASH Note the thick bar/brace. THe RSX DASH is Heavy. It has the steering column and wheel attached. It also has the dash/non engine fuse box and most of the dash wiring attached. http://img.photobucket.com/albums/v3...h/102_2224.jpg The AC/heater blower vent hole that the RSX blower box has to line up with. http://img.photobucket.com/albums/v3...h/102_2165.jpg AC heater blower box http://img.photobucket.com/albums/v3...h/102_2215.jpg Making room for the AC/Heater blower box. The Teg airbag control module needs to be removed along with its bracket and replaced with the RSX unit in a different location. The Ac blower is too tall to allow it to remain in this location. http://img.photobucket.com/albums/v3...h/102_2217.jpg Out with the airbag control unit http://img.photobucket.com/albums/v3...h/102_2218.jpg 1st dry test fit of the dash. It's too far forward and too low. Some things must be cut more! http://img.photobucket.com/albums/v3...h/102_2229.jpg Cutting the defroster plastic from the dash to allow it to slide in further. http://img.photobucket.com/albums/v3...h/102_2233.jpg The 2nd dry fit. http://img.photobucket.com/albums/v3...h/102_2234.jpg 2nd dry fit from rear of car. Still sits a bit too low. http://img.photobucket.com/albums/v3...h/102_2235.jpg The door panel on the 2nd dry fit, as you can see it needs to come up a bit. http://img.photobucket.com/albums/v3...h/102_2239.jpg Cutting the rest of the airbag control unit mounts. The RSX blower is HUGE compared to the integra unit. It takes up every inch! http://img.photobucket.com/albums/v3...h/102_2240.jpg The little bump pictured needed a little banging to allow the dash brace to fit. The little mount next to it was removed as well. http://img.photobucket.com/albums/v3...h/102_2242.jpg The steering column mount needs to be trimmed a little more. Look at the RSX interior firewall Reference pic above to see the dif between the teg and RSX http://img.photobucket.com/albums/v3...h/102_2244.jpg Some minor cutting of the dash brace on the passenger side to allow more clearance. http://img.photobucket.com/albums/v3...h/102_2243.jpg Some minor cutting of the dash brace on the passenger side to allow more clearance. http://img.photobucket.com/albums/v3...h/102_2247.jpg Some more minor cutting of the dash plastic to clear the a pillar on the passenger side to allow more clearance. FITMENT ISSUE RESOLUTION FOR THE RSX AC BLOWER! As I said earlier, the RSX ac box is huge. It has motorized controls for the vent selector flaps, hepa air filters and is shaped totally differently from the integra. It took lots of measuring and a bit of cutting, but things are coming together well. I am going to try to do this with as little cutting and drastic modification to the integra as possible. I am aiming to not have any downsides to the project, like things not fitting and not being able to get to the pedals due to the dash being in the way. More text soon, but for now, here are some more pics..... http://img.photobucket.com/albums/v3...h/102_2238.jpg Integra Firewall before cutting for the a/c box. http://img.photobucket.com/albums/v3...h/102_2241.jpg Section to be trimmed to fit the a/c box. http://img.photobucket.com/albums/v3...h/102_2249.jpg After cutting for the a/c box. http://img.photobucket.com/albums/v3...h/102_2259.jpg A/c box resting in place. http://img.photobucket.com/albums/v3...h/102_2260.jpg Another angle of the a/c box in its new location in the Integra. The steering column bracket has been trimmed and now closely resembles the RSX. It only acts as a brace for the brake pedal now. I'm waiting on motor mounts and a center console. My RSX was missing the console when I got it. Final locations for everything will depend on the center console and engine mounts. So I guess I could wire the doors up now. I cut the wires that go to the headlights, fans etc on the passenger side of the engine bay by the ABS and left them all plugged in for now. I am left with a nice neat pony tail. http://www.we-todd-did-racing.com/th...x/102_2138.JPG As you may recall, the harnesses from the integra were removed. I had cut the bundle of wires going into the door, leaving a ponytail by the passenger kick panel/ original ecu location. I did the same on the drivers door. http://img.photobucket.com/albums/v3...h/102_2272.jpg I unwrapped the integra harness and separated the bundle of wires for the door systems (power windows, mirrors and door locks). http://img.photobucket.com/albums/v3...h/102_2273.jpg I then reconnected the new separated harness to the places they were cut. This totaled about 20 wires. I soldered and shrink tubed all of them. They will be added to the final harness after all the separate systems in the entire car have been wired and tested. http://img.photobucket.com/albums/v3...h/102_2269.jpg ALL OF THE DOOR SYSTEMS WORK! I have tested everything and it all good! I can move on to the next part. I'll decide what that is tomorrow. As the project progresses I will log all of my wiring for future reference. K20 Hasport MountsHasport Mounts have arrived. Time to take out the old auto tranny mount, test fit the new mounts and drill holes for the bolts on the new K series Passenger frame rail mount. http://memimage.cardomain.net/member...90_34_full.jpg There is the old mount and an engine bay that is starting to look a little more empty. An air autobody saw makes this job easier! http://memimage.cardomain.net/member...90_35_full.jpg http://memimage.cardomain.net/member...90_36_full.jpg http://memimage.cardomain.net/member...90_37_full.jpg After the lower part of the mount is free from the framerail some leverage and prying will pop the upper part off. Be patient and wear eye protection! http://memimage.cardomain.net/member...90_38_full.jpg The new mount in place. http://memimage.cardomain.net/member...90_39_full.jpg http://memimage.cardomain.net/member...90_40_full.jpg Just line up the bottom holes with the original lower fraimrail mount holes and mark, drill and bolt it up! Keep in mind, this is the dry fit for everything. Things will be removed, and there will be lots of cleaning and painting! http://memimage.cardomain.net/member...90_41_full.jpg [B]Mounting the RSX Under Hood Fuse box [B] http://memimage.cardomain.net/member...90_43_full.jpg Drilling holes for the fuse box mount from the RSX. This is the factory location for the RSX and makes wires reach what they are supposed to. http://memimage.cardomain.net/member...90_44_full.jpg Mount for RSX fuse box installed. FUSE BOX INSTALLED http://memimage.cardomain.net/member...90_45_full.jpg Closed hood view. http://memimage.cardomain.net/member...90_46_full.jpg http://memimage.cardomain.net/member...90_47_full.jpg As you can see, it fits like a glove. RSX ABS Install on the DC2...In a custom location! ;) http://memimage.cardomain.net/member...90_48_full.jpg Here is the RSX ABS Unit. You may ask, "Why not just eliminate it?". That would be too easy. The RSX ABS Unit is way smaller than the Integra, and therefore lighter as well! What about the ugly lines all over the engine bay? Well here's my solution. http://memimage.cardomain.net/member...90_51_full.jpg The RSX clutch cylinder is remotly located and smaller, and the brake booster is smaller. The Integra wiring that went through the firewall between the brake booser and the driver fender is eliminated. IE More space! http://memimage.cardomain.net/member...90_50_full.jpg So I decided since there is room, I would put the ABS here. With this location wire length for the 13 ABS wires is reduced by 6 feet to only about 18 inches! Also, the hard brake lines are only in the engine bay for a foot, in a hidden location. I will only have 1 brake line to run to the passenger front brake. Just look at the pics. Once the line are installed it will be more understandable. http://memimage.cardomain.net/member...90_49_full.jpg http://memimage.cardomain.net/member...90_52_full.jpg Some simple modification of OE mounts and it bolts right in. I'll add more on this later. http://memimage.cardomain.net/member...90_53_full.jpg Blurry close up of the new location for the RSX ABS, brake booster and Clutch cylinder. The clutch lever needs to be extended. I'll update this with the fix. I'm doing the harness for the engine bay. This is going to be a tuck and rewire to run the Integra lamps and RSX everything else! Modified by tamparacer at 8:27 PM 4/17/2007 UPDATE MAY 01 2007 OK, so here's the latest. We have been cutting and test fitting the ac box to make sure we had it in the correct position. This measurement was critical, as the final location for everything from the dash to the center console, shifter, and e-brake, steering wheel all are determined by this airbox location. There was a lot of putting in and taking out of the dash and ac box. There were minor cuts and bangs made to the dash and car. To avoid overcutting and hacking up the car, we cut a little at a time. I would guess we had the dash in and out 10 times to get it just right. Next time will be much easier for me. Maybe this will be a sticky and save some other brave person some hassles. As far as I know, when finished, I will be the first person to do a fully functional RSX dash in a DC2. If someone else cain claim otherwise, PLEASE post some pics! So with that said, here's the update. http://memimage.cardomain.net/member...90_67_full.jpg Above is the passenger mount for the RSX dash, in the RSX. The mount was drilled off to be used on the DC2. The smaller mount is to mount the blower fan housing. This will mount be added to the Integra by making a new bracket. http://memimage.cardomain.net/member...90_68_full.jpg http://memimage.cardomain.net/member...90_69_full.jpg Above: The RSX dash had a frame and skin type design. To allow us to more easily see what we were doing, we disassembled the dash and removed the plastic skin, shell, cover, or whatever you choose to call it. http://memimage.cardomain.net/member...90_70_full.jpg Above: This is the entire behind dash A/C heat system installed. Mounts will be fabricated to allow mounting using mostly OE bolts and mounting locations. http://memimage.cardomain.net/member...90_71_full.jpg Above: This is the frame structure for the RSX dash. It is being test fit for its last time before welding in the mount. We screwed it in place with tine screw on the upper side mounting brackets this allowed us to pivot the dash to tilt it up or down. This allowed us to test fit the center console and determine the final angle of the dash. A little too much tilt up, the end of your console would be aiming at your hatch glass. Once this was determined it was time to weld. http://memimage.cardomain.net/member...90_72_full.jpg Above: A test to make sure the welder is ready to go. http://memimage.cardomain.net/member...90_75_full.jpg Here is the mount, tacked and ready for welding. http://memimage.cardomain.net/member...90_76_full.jpg So here gos nothing. It worked, but wasn't worth showing off. I'll let the pro pretty it up later. All of this is coming back out again before final assembly. http://memimage.cardomain.net/member...90_78_full.jpg Above: The dash skin has been reattached to the dash frame and then the dash assembly was bolted in place! That brace has to add some stiffining and safety. It seems like a nice thing to attach a roll cage to, if you needed one. The center console is just snapped onto the dash. Mounts will be made and the shifter box from the rsx should fit without any special adapter since I'm using an RSX console, and not the stock one. The only thing I hate is that there is no armrest. I think I'll have to address that later. Below: Some more angles and fitment photos. As you can see, it fits a 6' person perfectly. It had plenty of adjustability and feels like a stock car. I couldn't be happier. The door panels will be reworked to fit perfectly. The seats will be replace with RSX seats. I'm just not there yet. http://memimage.cardomain.net/member...90_79_full.jpg http://memimage.cardomain.net/member...90_80_full.jpg http://memimage.cardomain.net/member...90_81_full.jpg http://memimage.cardomain.net/member...90_83_full.jpg http://memimage.cardomain.net/member...90_84_full.jpg http://memimage.cardomain.net/member...90_86_full.jpg http://memimage.cardomain.net/member...90_85_full.jpg http://memimage.cardomain.net/member...90_87_full.jpg SO there you go for tonight. The next step is mounting the E brake handle and shifter, as well as mounting several things including the ECU and airbag electronics. UPDATE (AUGUST 1 2007) Item we were waiting for arrived recently. -SSR(Six Sigma Racing) stainless header 4-2-1 -G Eagle fuel rail -AEM FPR -Walbro fuel pump WIRING!!!!!!!! Wiring conversion is almost complete. So far it has taken 2 of us 8 hours to complete 90% of the wiring. Systems wired and tested so far are: A/C, blower and controls, exterior lamps (all), Integrated OEM alarm with immobilizer (no hondata), Converted or modified Items wired but waiting for the engine/startup to be tested Wheel Speed sensors (integra on car side, rsx s on ecu side) ABS (Integra brakes/lines, rsx s ABS system) Everything under the hood is ready for the k20z1 to be dropped in and plugged into factory rsx plugs car side. Hatch lid and roof systems still not wired, next week the engine goes in. What we did was remove the entire Integra harness and laid the rsx harness in the car. We routed it to lay as it would in the rsx. We then unwrapped the harness from the firewall forward and the dash back, leaving almost every wire under the dash alone. We then seperated each subharness and grouped the wires to each system seperately. We then routed and adjusted lengths of every wire for a perfect fit.Here are pics, descriptions to be added to each one. http://img.photobucket.com/albums/v3...h/100_2741.jpg http://img.photobucket.com/albums/v3...h/100_2742.jpg http://img.photobucket.com/albums/v3...h/100_2743.jpg http://img.photobucket.com/albums/v3...h/100_2744.jpg http://img.photobucket.com/albums/v3...h/100_2746.jpg http://img.photobucket.com/albums/v3...h/100_2748.jpg http://img.photobucket.com/albums/v3...h/100_2750.jpg http://img.photobucket.com/albums/v3...h/100_2751.jpg http://img.photobucket.com/albums/v3...h/100_2752.jpg http://img.photobucket.com/albums/v3...h/100_2753.jpg http://img.photobucket.com/albums/v3...h/100_2755.jpg http://img.photobucket.com/albums/v3...h/100_2756.jpg http://img.photobucket.com/albums/v3...h/100_2757.jpg http://img.photobucket.com/albums/v3...h/100_2758.jpg http://img.photobucket.com/albums/v3...h/100_2759.jpg http://img.photobucket.com/albums/v3...h/100_2760.jpg http://img.photobucket.com/albums/v3...h/100_2763.jpg http://img.photobucket.com/albums/v3...h/100_2766.jpg http://img.photobucket.com/albums/v3...h/100_2768.jpg http://img.photobucket.com/albums/v3...h/100_2769.jpg Here are some videos of the oem RSX keyless entry and alarm with immobilizer in the integra. It was dark, so I'll add better vids later, when there is more exciting stuff to show. Video of RSX dash and ac blower working. All engine componets (swap) are yet to be installed. (next week) Dash test YouTube - rsx dash test in integra alarm test front: YouTube - rsx dash conversion dc2 integra swap test alarm rear YouTube - RSX Conversion DC2 k20z1 swap Alarm test in dark YouTube - rsx dash conversion dc2 integra swap test The good part: K20z1 swap....................... http://img.photobucket.com/albums/v3...h/100_2807.jpg http://img.photobucket.com/albums/v3...h/100_2808.jpg http://img.photobucket.com/albums/v3...h/100_2809.jpg http://img.photobucket.com/albums/v3...h/100_2810.jpg http://img.photobucket.com/albums/v3...h/100_2811.jpg http://img.photobucket.com/albums/v3...h/100_2812.jpg http://img.photobucket.com/albums/v3...h/100_2813.jpg http://img.photobucket.com/albums/v3...h/100_2814.jpg http://img.photobucket.com/albums/v3...h/100_2815.jpg http://img.photobucket.com/albums/v3...h/100_2816.jpg http://img.photobucket.com/albums/v3...h/100_2817.jpg http://img.photobucket.com/albums/v3...h/100_2819.jpg http://img.photobucket.com/albums/v3...h/100_2820.jpg http://img.photobucket.com/albums/v3...h/100_2821.jpg http://img.photobucket.com/albums/v3...h/100_2822.jpg http://img.photobucket.com/albums/v3...h/100_2823.jpg http://img.photobucket.com/albums/v3...h/100_2824.jpg http://img.photobucket.com/albums/v3...h/100_2825.jpg http://img.photobucket.com/albums/v3...h/100_2826.jpg http://img.photobucket.com/albums/v3...h/100_2827.jpg http://img.photobucket.com/albums/v3...h/100_2828.jpg http://img.photobucket.com/albums/v3...h/100_2829.jpg http://img.photobucket.com/albums/v3...h/100_2830.jpg http://img.photobucket.com/albums/v3...h/100_2836.jpg http://img.photobucket.com/albums/v3...h/100_2837.jpg http://img.photobucket.com/albums/v3...h/100_2838.jpg UPDATE 9-4-07 We have most of the vital things wired, connected, routed......blah blah. We started the car, and it fired right up ad runs fine. http://img.photobucket.com/albums/v3...a/100_2899.jpg http://img.photobucket.com/albums/v3...a/100_2898.jpg Above, Stock RSX heater hoses are in place and fit perfectly without cutting. http://img.photobucket.com/albums/v3...a/100_2897.jpg http://img.photobucket.com/albums/v3...a/100_2875.jpg http://img.photobucket.com/albums/v3...a/100_2873.jpg Aeromotive FPR and golden eagle fuel rail with -6AN steel hoses http://img.photobucket.com/albums/v3...a/100_2896.jpg B series upper radiator hose was trimmed a few inches on both ends and fit perfectly between the engine and the OEM RSX radiator. http://img.photobucket.com/albums/v3...a/100_2895.jpg RSX cruise control and evap unit in place. http://img.photobucket.com/albums/v3...a/100_2892.jpg http://img.photobucket.com/albums/v3...a/100_2890.jpg http://img.photobucket.com/albums/v3...a/100_2894.jpg RSX Ebrake handle is installed, attached to the Integra cables. Next to do: We are working on extending parts of the brake pedal and clutch pedal connections to the master cyls, and have to extend the steering column as well. We will be making our own axles using b series outer hubs and RSX everything else. Rework the stock RSX exhaust to fit the integra. UPDATE: 9-20-07 Steering column and brake/clutch pedals are adapted to fit, and work great. I'll update again soon! |
sweet project. thanks for posting.
Badass buildup, should be a nice head turner when it is done, custom lines for ac?
Originally Posted by PooN_Lude
(Post 4053690)
Originally Posted by uyht
(Post 4053687)
hey when you get done do you want to do it to my integra??
Originally Posted by Turbo Teggy
(Post 4053904)
thats a time consuming and really nice work done...
really cool.... |
I really appreciate those of you who enjoy my threads, but when people on here are just plain dicks about stupid teenager BS really make me hate this website.
nice, I wonder if u can get an 05 civic in a 95 civic
