Problem with Cylinder #4
Old Mar 30, 2007 | 08:23 PM
Tightcivicexboii's Avatar
Honda Gear Head
Default Problem with Cylinder #4
Alright my car is a 91 CRX Dx with a B18B1 completely rebuilt long block and a OBD0 LS cable tranny. Everything was rebuilt right and time was tooken on the motor. Rings were replaced so i know how the short block is looking. The thing is that the head was given to be looked at. Afterwards, the new OEM head gasket that was put on was not replaced after the head was pulled off again, but the head was on for only a while and the car was checked out to see if it was gonna fire up ghood and everything was done right and it was. But then the thoughts of having someone port and polish it played in mind and thats when it was pulled again. To make a long story short, the head never got port n polished and it was laid back down on the same head gasket. The motor is completely well except the fact that cylinder #4 is misfiring - sounding like the #4 spark plug wire was pulled, but it's not. I want to know can this #4 cylinder become alright if i was to just replace the head gasket? Because it has low compression after the compression test was performed and the rest are at normal compression readings. Real answers are appreciated, thanks.
No project currently. Getting my ASE Certifications Completed.
Old Mar 31, 2007 | 12:47 PM
custom240sx's Avatar
DC Crew Member #1
Did you pull the spark plug and put a new one in there and see if that fixes anything...I fried one plug running nitrous before in cylinder 3 and it sounded like I had some nasty cams in the car.
Old Mar 31, 2007 | 02:07 PM
magic carpet's Avatar
it could very easily be the head gasket
Old Apr 1, 2007 | 06:53 PM
Honda Gear Head
Thanks to both, but i never thought of the spark plugs doing that and i mean i ws gonna buy new spark plugs, well i guess i'll do a tune up in the car aswell, but definately i'll replace the head gasket.
Old Apr 3, 2007 | 06:20 AM
Honda Gear Head
I'm hoping that the oil being within the spark plug area is just a bad spark plug grommet. I'm replacing all this today.
Old Apr 4, 2007 | 05:41 AM
Honda Gear Head
Head gasket, spark plug grommet and seals, Valve Cover gasket, Spark plugs, and spark plug wires. All been changed.
