obd0 harness need to rewire for obd1 p28 ecu (HELP)
Old Mar 20, 2007 | 06:34 PM
HatchBack91's Avatar
Oldschool
Exclamation obd0 harness need to rewire for obd1 p28 ecu (HELP)
I CANT FIND A WIRING DIAGRAM ANYWHERE!!!! NEED TO GET IT DONE!
i did a mini me swap and also heard that i need a 4 wire o2 sen. is that true? if so what kind of car has the 4 wire o2 i need i have a vtec head off a del sol! it starts i had the dizzy rewired to obd0 and im getting spark but still wont start im running a p28 ecu now so what can i do??????
Old Mar 22, 2007 | 05:30 PM
60-1EK's Avatar
Engineer at the source
You can not run the OBD1 ecu with the pre-obd(OBD0) distributor. If you want to run the OBD1 ecu, you will need the OBD1/2 distributor. If you are running a chipped ecu, you can disable the 4 wire O2 sensor need.
Rywire - Online Store can help you out.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Mar 23, 2007 | 07:59 AM
nocomply540's Avatar
is retired...
not to thread jack but can I have just the speed limiter removed from an obdo ecu??
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
Old Mar 23, 2007 | 12:46 PM
89civrex's Avatar
89civrex
diagram is on boosted.org/ecu
