Turbocharged Acura RDX.
I haven't read much into the new RDX, but sounds like Honda's putting the right foot forward. Although the power output seems less then impressive, along with the gas mileage. I hope this will be the start of something good. Turbo Si's from the factory? 300bhp Civic? Would be nice.
Rated output for the RDX engine is 240 horsepower SAE net* at 6000 rpm. In terms of torque, the RDX has the highest output of any engine in the Acura lineup, with 260 lbs.-ft. of torque SAE net* at 4500 rpm. The RDX is expected to return an EPA-estimated 19/24** City/Highway mileage, while meeting strict CARB LEV-2 ULEV and EPA Tier-2 Bin-5 emissions standards. A 5-speed automatic transmission with Sequential SportShift is standard. The electronically controlled drive-by-wire throttle and transmission work together to execute shifts, resulting in exceptionally quick and smooth gear changes. The transmission can function as a conventional automatic transmission or, at the driver's option, can be shifted manually via steering-wheel-mounted paddles. SH-AWD™ is standard in the RDX to maximize available traction while improving handling balance and responsiveness. SH-AWD™ is Acura’s patented all-wheel drive system that distributes the optimum amount of torque not only between the front and rear axles but also between the left and right rear wheels. The system’s direct yaw control helps reduce understeer to enhance steering accuracy and add to total cornering power. |
its too bad that its way to hard to swap them into a civic. haha that would be tits
i want a heavy ass under powered engine that gets shitty gas mileage that i have to spend major bucks to be fitted into my car.
Edit: I think the RDX is fly. i'd rock it. |
been selling the RDX injectors by the hundreds lately ,lol
Originally Posted by BERT-O
(Post 3994081)
i think 410cc and like 40bucks each
Originally Posted by 99B16Si
(Post 3994487)
