Air getting in my clutch line!!! wtf!?
Old Feb 26, 2007 | 05:36 PM
94lsteg's Avatar
BOOST IS BETTER!
Default Air getting in my clutch line!!! wtf!?
I've changed the slave twice....that cant be the problem. I'm not leaking any fluid. I'll bleed it, it catches for a couple days, then it will start building air again and the pedal gets stiff at the bottom. Bleed it again and it works again....its annoying. Is the master cyl the last thing it could be? thanks
Old Feb 26, 2007 | 05:38 PM
TSX24L's Avatar
generally you replace master cylinder and slave at the same repair. If one was leaking most then likey and from experience the other is to. Its wise to replace both. 9/10 this is your problem. A visual leak doesn't mean that the master isn't leaking fluid under the dash, could be internally bypassing.
Old Feb 26, 2007 | 05:39 PM
Ink's Avatar
Ink
Changes names a lot.
yes, it happened to me with my car and was either master/slave cylinder. only difference is i would lose pressure in my clutch. mine was the slave and fixed so yours im 99% sure is the master cylinder.
Old Feb 26, 2007 | 05:52 PM
94lsteg's Avatar
BOOST IS BETTER!
tru shit ,thx guys
Old Feb 26, 2007 | 05:55 PM
sprjit22's Avatar
Rick James bitch
yeah master. the clutch system only consists of a few things. master cylinder - steel lines - high pressure rubber line - slave
The issue lies some where in their.
no visual leaks = not rubber line or steel line
new slave = already replaced
only one thing left master cylinder
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old Feb 26, 2007 | 06:20 PM
94lsteg's Avatar
BOOST IS BETTER!
just bought one. we shall seeee!! cant wait till i can actually chirp 2nd...geeez, whut does a man have to do JUST to chirp 2nd!!!!!!!!!
Old Mar 7, 2007 | 11:43 AM
94lsteg's Avatar
BOOST IS BETTER!
FIXED! yup, master cyl!
