rear discs on a 4dr EG
what ebrake cables do i use to put disc brakes on the rear of a 4 door EG?
i'm assuming everything else will just bolt right on, correct? |
my guess would be anything from 94up integra because of length of th parking brake cables. since no one is answering. :(
i would say the cables from a 4 dr teg would fit the 4 dr coulpe the best...if you are going to have to buy them..
4 door eg EX with ABS came with rear disc..........get oem cables and they will work perfect..fit everytime.......i had a 93 dx 4 door and used 95 gsr rear disc withfactory e bake cables...no problems at all....can get oem part # if u want
thatd be great!! thanks alot man!
yes part numbers and i'd buy you a beer sometime. |
do you have a parts supplier? if not, these are they guys that i get all my honda parts from:
Majestic Honda - The Internet's #1 Honda Automotive Parts Store |
yeah i have two very good friends of mine that work at a honda parts counter ;) thanks though
parts #'s:
right: 47510-SR4-933 left: 47560-S04-932 |
I used 99-00 Si cables on my four door and they worked fine...
