makes noise when clutch is not engaged
Old Jan 30, 2007 | 06:49 PM
carcustomizer's Avatar
Carbon Fiber/Nismo Addict
Default makes noise when clutch is not engaged
my homeboi has an 00 EK hatch, single cam, non vtec. And when the clutch isn't in, it makes like a light grinding noise. But when he puts the clutch in, it goes away. What's goin on here?? thanks.
- Noel
Listen to Trance, House, and/or Progressive music? Check out my mixes, I think you might like 'em
Vehicular Résumé
'93 Nissan 240sx Hatch (Sold)
'91 Nissan 240sx Hatch (Sold)
'91 Nissan Maxima SE (Died [Blown Tranny @ 250k+ mi])
Old Jan 30, 2007 | 07:15 PM
Obviousreasons's Avatar
Welcome to Candy Mountain
Probably the throwout bearing. But could be something else as well. What about when he puts light pressure on the pedal?
Need your Honda/Acura tuned? Ecu Chipped?
Http://www.Phearable.net
Need some Stereo/Security/Video Work Done? Almost Anything 12 Volt I can do. 12 Years Experience. Send a PM For Inquiries.....
Old Jan 30, 2007 | 07:34 PM
ya, i was thinking that too. it still makes the sound i think even if put light pressure on it.
- Noel
Vehicular Résumé
Old Jan 30, 2007 | 07:43 PM
aznkhmerracernza's Avatar
It's either the Throwout Bearing or Pilot Bearing
USS MAINE BLUE CREW, BANGOR WASHINGTON!!
www.myspace.com/maknpanna
Old Jan 30, 2007 | 07:46 PM
Might wanna pull the tranny and check that one out.
Old Jan 30, 2007 | 08:24 PM
civicized's Avatar
It's likely the mainshaft bearing in the trans. Possibly a pilot bearing, but if it is a serious, deeper sounding grinding, it likely is inside the trans.
What's happening is the mainshaft of the trans always spins with the clutch is not engaged, even when the trans is in neutral. Thus you hear the noise. Depress the clutch and the mainshaft is no longer spinning - noise goes away.
Should also make the noise when the car is moving, though it can be hard to hear.
Throwout bearings make the most noise when the clutch is pressed. If they are bad, that's when you'll know it.
