Does the honda 1.5 vtec engine uses p28 ecu
Old Jan 7, 2007 | 07:36 AM
CivicRacingFL's Avatar
Dorado, PR
Default Does the honda 1.5 vtec engine uses p28 ecu
like title says does the 1.5 vtec engine uses the p28 ecu, if not which one is it. thank you
Old Jan 7, 2007 | 10:43 AM
JellY's Avatar
yes a p28 will work with the d15b
Old Jan 7, 2007 | 01:21 PM
unique intensions's Avatar
Yeah, you could use the p28 but the swap comes with the p08.
Old Jan 7, 2007 | 06:09 PM
Dorado, PR
which one is best to have it with the p28 or p08, and if i use the p28 do i have to do any mods or is plug n play
Old Jan 7, 2007 | 07:35 PM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
basically almost identical maps in ecu....d15b has just a slight bump in compression, so if u dont plan on being tuned, i would just run the correct ecu with the motor.....but if u r going to have tuning done, p28 is the ecu to have....staple of honda ecu tuning
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Jan 8, 2007 | 02:49 PM
Yo, I dont know how true this is but I was told if you use the p28 on the d15 motor that you have to use the IM off of the z6 so it wouldn't throw a code. But I dont know how true that is. But if anyone could brake that down for me a see if that is true cause I'm doing a d15 swap in my wifes car. And I want to be sure that when I swap the motor and trans that I dont fall into any problems.
Old Jan 13, 2007 | 01:15 PM
89civrex's Avatar
89civrex
if the p28 dont work ill buy it
