Car Wont Start
Old Dec 31, 2006 | 08:39 AM
Grizzly0205's Avatar
**BoTtLeS aRe 4 BaBiEs**
Default Car Wont Start
I came home from work and the next morning i go out to start my car and I turn the key and nothing happens. The cd player lights and everything comes on but when i try to start it up it wont even try and turn over and i dont hear a clicking noise from the starter or anything. Any info will be appreciated greatly as soon as possible because i am trying to avoid having to have it towed to work (tire kingdom) where i can have the tech there look at it because I am trying to save my money because i need a new radiator in my other car. O yea the car is a 92 integra with a b16 motor. thanks
Old Dec 31, 2006 | 08:42 AM
or if you live in the st pete area or willing to come look at it i would rather use the money for towing TOWARDS the cost to pay someone to fix it.
Old Dec 31, 2006 | 08:43 AM
mtber's Avatar
Could be your clutch switch.
If you hear the fuel pump turn on & the main relay click when you turn the key to the 2nd click accessories position, but your car does not crank when turning the key further... Try using some wire to manually send a 12v signal to the starter signal wire on the starter to see if the starter turns over & possibly starts the car...
If it does start your car, my bet is that your clutch switch is bad.
If you do not hear the main relay click or the fuel pump prime etc, your problem maybe your main relay located on the drivers side under the dash.
Good luck.
Old Dec 31, 2006 | 09:33 AM
i just went out there and i dont hear anything when i turn it to the accessories i just hear the beaping noise but i wiggled some wires under the dash and i heard a little click every time i wiggled it but i looked down under the pass side under the carpet and im guessing this is the ecu i honestly dont know if it is or not just my guess but theres two wires going from there to the engine bay ( 2 wires that someone spliced in there) and they are unconnected i have a pic and im trying to get it posted asap.. i really appreciate the help
Old Dec 31, 2006 | 10:36 AM
B20eg4dr's Avatar
Clueless...
the clicking sound is very faint. it should happen after the CEL goes out. you will have to listen for it. as for the fuel pump it is a slight (very slight) whirlling sound. Maybe a slight buzzing type of sound. Just put it to on and give it a minute. If you dont hear those then there is a good chance it could be your main relay. If you do, look on your floor board for some clearish rubber pieces. The little rubber piece that activates the safety switch to the started from the clutch may have broken apart. This happened to me and I had the same symptoms. If you can push start it then it is either your starter or the clutch safety switch. Let us know what happens. Good luck bro.
Old Jan 4, 2007 | 08:26 PM
i appreciate everything i finally found out but i guess there was no power getting to the starter and after he fixed it the car will start up without me even having to push the clutch in where as before i had to....
Old Jan 4, 2007 | 08:59 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
wait....a manual car that you don't have to push the clutch in to start?what did he mess with?
-Winston Churchill
Old Jan 6, 2007 | 11:00 PM
So when you push started it, what did your guy at work say was wrong with it?-Bob
