Integra speedometer ?
Old Dec 23, 2006 | 02:33 PM
96dxholder's Avatar
I heart my DC!
Default Integra speedometer ?
i have an LS with GSR tranny and cluster. the speedo works fine when its cold, but when it is hot outside is a different story, it stays at zero or sticks at a number. i tried changing the VSS and it still did not fix it. anyone got any ideas?
thanks,
matt
Old Dec 23, 2006 | 02:48 PM
JDMBlackGSR's Avatar
Gators Bitches!
do you still have your old cluster? if so, change out the back green chip sheet, and see if that works, my have been a different year. Thats what I did with my JDM ITR Cluster into my RS.
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
Old Dec 23, 2006 | 03:39 PM
96dxholder's Avatar
I heart my DC!
the cluster came in the car so. i know the tranny is a 1996, but i dont know about the cluster.
Old Dec 23, 2006 | 05:55 PM
00TEGLS's Avatar
You have a bad speedo head. Try another good cluster.
Old Dec 24, 2006 | 08:36 AM
96dxholder's Avatar
I heart my DC!
ok thank you sir! i will try that.
